Speedometer help! - Mustang Evolution
Old 08-03-2011, 05:42 PM   #1
89 Foxloco's Avatar
Speedometer help!
I have a 89 gt 5.0.my speedometer goes to 85 top speed. What changes or replace do I have to do so it can go to 140 mph. Most people say change the transmission and some say the gears so I just want to know more opinions.. Thanks!!
89 Foxloco is offline   Reply With Quote
Old 08-03-2011, 05:58 PM   #2
Re: Speedometer help!
You asked how to have a speedometer that goes to 140 MPH correct?
If yes, then:
D. None of the above.
To have a speedometer that reads to 140 MPH you will have to replace it with one that goes that far. 140 MPH Speedo
Old 08-04-2011, 02:53 AM   #3
89 Foxloco's Avatar
No..ok..my original cluster says 85 mph top.. I have another cluster that says 140 mph.I installed out but the needle kept reading the speed of the 85 on the 140.hope I explain my self good..am trying to make my car go more than 85 top speed.so I would like to know what I need to change.. Thank you..
Old 08-04-2011, 03:25 AM   #4
What car do you have, what engine, transmission, etc. etc.
List any modifications you have too.
Old 08-04-2011, 04:33 AM   #5
89 Foxloco's Avatar
I have a 1989 mustang fox body 5.0 302 block.all stock with a manual transmission.all stock.
Old 08-04-2011, 05:59 AM   #6
93slowstang's Avatar
Is it showing the correct speed, and does the car still gain speed after it stops at 85?
Old 08-04-2011, 09:11 AM   #7
nickcap's Avatar
there might be some kind of computer chip in it that stops it at 85...
1995 Mustang GT Convertible!! (My Baby Monique) Ha
nickcap is offline   Reply With Quote
Old 08-04-2011, 04:21 PM   #8
89 Foxloco's Avatar
@ 93slowstang its doesn't show the correct speed on the 140 cluster.. Yes but a lol and the transmission shakes alot when I try to push it more.. @ probably its the chip or something..
Old 08-04-2011, 04:41 PM   #9
Then you may have something going wrong in the transmission.
Are you sure no one changed the gears in the rear end?
Old 08-04-2011, 11:45 PM   #10
Brandon91's Avatar
You just need to buy a new cluster that goes to 140.. Then a new speedo gear that is calibrated to go to 140. That's it.
Brandon91 is offline   Reply With Quote
Old 08-05-2011, 12:11 AM   #11
Sorry, but speedo gears are not "calibrated" to go 140.
All I did in my 86 GT was to install the 140 MPH speedometer into the gauge cluster.
He has some other issue or issues to sort out.
Old 08-05-2011, 05:06 AM   #12
89 Foxloco's Avatar
I'll get opinions from other people people but thank you guys any way..it was seriously helpful..am just going to connect what you guys said with what other people say and connect it and see which one is more right..thanks..
Old 08-07-2011, 03:44 PM   #13
Stang.racr's Avatar
i have 91 that had a 140 on it and it messed up, i took the 140 out and replaced it with an older cluster that said 85, i made no other changes. now my speed odimiter wasn't all the way correct due to me running 28 inch tires instead of a 26 but it was pretty close. you are suppose to change your speedometer gear to correct your speedometer if you change your gears, the speedometer gear and clip kit cost 10 bucks and is easy to put in. the gear attaches to the speed sensor and it relays info to the computer to let it know the sped of the transmission output shaft. hope this helps
coming from a guy that uses tom tom cause his speedometer is a floating pos
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 08-07-2011, 05:23 PM   #14
89 Foxloco's Avatar
Awsome.thanks..I'll check that out..
HELP!!!!! :( vinnygt 1996-2004 Mustang GT 5 07-23-2011 10:37 PM
Free saleen speedometer Qwik Four Six 1979-1995 Mustang GT 12 06-25-2011 05:05 PM
11:03 AM
