Car shutting off - Mustang Evolution
Old 08-04-2011, 07:07 PM   #1
93slowstang's Avatar
Car shutting off
Can anyone think of what you cause my car to all of a sudden shut off? My fuel pump is working fine as I've checked it plugs,and wires.
I'm also getting spark and my ignition module is fine too. I'm running out of ideas and thinking it's either my ECM or maf. Any thoughts?
Old 08-04-2011, 07:09 PM   #2
Las0mbra's Avatar
Is it throwing codes?
Old 08-04-2011, 07:14 PM   #3
Jamesgt08's Avatar
Vacuum leak. Check ur hoses.
Jamesgt08 is offline   Reply With Quote
Old 08-04-2011, 07:19 PM   #4
That's another thing, I've tried checking it before and the test ports aren't working. Took it to a mechanic and they couldn't get it to read either. Found out it was an auto converted to manual with an a9l computer an they didn't add the part of the harness needed.
---------- Post added at 08:16 PM ---------- Previous post was at 08:15 PM ----------
I've checked them too.
---------- Post added at 08:19 PM ---------- Previous post was at 08:16 PM ----------
Forgot to add that if I reset the computer it will crank and run fine for about 10 minutes and just shut off.
Old 08-05-2011, 12:07 AM   #5
Re: Car shutting off
How do you "reset" the computer, disconnect the battery?
Sounds like something is getting hot and shutting down in your ECU or ignition system.
Check all of your ground wires, especially to the engine and ECU.
Old 08-05-2011, 02:37 AM   #6
Yes I disconnected the ground to reset it. What's weird is I had my chip in the no run position with the key on and the fuel pump was running. When it was in any of the run settings it would only prime and not run.
Old 08-05-2011, 02:48 AM   #7
Have you tried it without the chip?
Maybe something in it shorted out.
Need to determine whether you are losing fire or fuel when it shuts down.
Check here - Ford Fuel Injection for information on testing the MAF and other wiring issues.
P.S. I love this site. Tons of info available.
Old 08-05-2011, 02:54 AM   #8
Yes I've taken the chip out too and it the pump works as it should until it cranks and then back to dying...
I'm at work right now but I'm gonna dive into that sight on break... Love new info
Old 08-05-2011, 06:34 AM   #9
Man that is a good write up, I bookmarked it for future reference. I decided to actually examine my ECM before diving into everything else and it looked like a bomb went off inside the casing.
Two of the capacitors exploded, and another ones connections are almost burnt off. On the bottom side quite a few of the paths are burnt up as well. That's just my luck.
Old 08-05-2011, 07:09 AM   #10
That sux.
Here's a list of compatible replacements in a MS Word document if you need it.
ECU/ECM/PCM (Computer) - List for the 87-93 5.0 Mustang
Old 08-05-2011, 07:40 AM   #11
That sux.
Thank you so much. You are a life saver, I have been looking for that for the past hour and a half. There really needs to be a thanks button on the app, it won't let me do it on the browser.
Favorite Thing About Your Car Thread bradh2414 General Mustang Discussion 43 07-24-2011 04:55 PM
Why does the a/c effect my car 1gt289 Pre-2005 V6 Mustang 22 07-23-2011 11:55 AM
My car is hurt :( GoldenPonyBoy 2005-2010 V6 Mustang 25 07-19-2011 10:11 PM
Car Covers! Murdered_Stang General Mustang Discussion 8 06-26-2011 03:03 PM
» Members Mustangs
007Stang
prm
Lisa
krgorham
Add your Mustang
02:06 PM
