I got a BIG PROBLEM!!! - Mustang Evolution
Old 08-04-2011, 08:54 PM   #1
nickcap's Avatar
Hey guys
I put everything back on and I go to start it and it turns over real slow! I put the jumper pack on it it still turns over in slow motion... Then I looked closely and right in front of the windshield there's smoke!!! Idk what to do or what this is I'm positive my spark plug wires are right order! Also I attached a pic of a plug that I do not know where it goes and if it causes the smoke please reply asap!!!
Thanks
NickCap
1995 Mustang GT Convertible!! (My Baby Monique) Ha
nickcap is offline   Reply With Quote
Old 08-05-2011, 12:03 AM   #2
Re: I got a BIG PROBLEM!!!
Originally Posted by nickcap View Post
Hey guys
Thanks
NickCap
Sorry, I don't know what the plug is in your picture.
Sounds like your timing is way off or you have a bad connection at your battery positive or ground cables.
Old 08-05-2011, 12:45 AM   #3
KELLY95's Avatar
Check your connection at your starter
KELLY95 is offline   Reply With Quote
Old 08-05-2011, 02:39 AM   #4
93slowstang's Avatar
That looks like a vacuum connection like the one that plugs to my evr
Old 08-05-2011, 02:49 AM   #5
Ohhhhhhhh that right there is the chingas that goes into the domingez In which powers the flex capacitor through the nuclear reactor of the after market vtech sticker that's essential for flight you can't forget that.. No need for thanks
16218 is offline   Reply With Quote
Old 08-05-2011, 04:00 AM   #6
Well no wonder it won't start......
Old 08-05-2011, 07:41 AM   #7
jsearcy's Avatar
Sounds like a ground. Almost sure of it to be honest
jsearcy is offline   Reply With Quote
Old 08-05-2011, 09:02 AM   #8
nickcap's Avatar
So where does it go now ha and thanks everyone for ur quick responses so where does that plug go
Old 08-05-2011, 09:08 AM   #9
Lapida's Avatar
Nickcap:
The plug is three vacuum hoses from the passenger side inside fender. One vacuum goes to the upper intake manifold and the others two hoses to the smog pump. I removed the smog pump on my 94 Cobra and I close the both hoses. I include a pic of the plugs. Feel free to contact me if you have any question.
Lapida is offline   Reply With Quote
Old 08-05-2011, 09:35 AM   #10
nickcap's Avatar
O so does it plug in or sorry I'm running a big blank
Old 08-05-2011, 11:40 AM   #11
nickcap's Avatar
I plugged it in the vaccunm hose and now it's still slow starts! Idk what's happening!!!!
Old 08-05-2011, 01:47 PM   #12
Did you check your timing and positive and negative connections?
Old 08-05-2011, 01:52 PM   #13
stampde's Avatar
that vacume connector HAS NOTHING to do with a slow crank , and neither would installing plugs and wires ........ unless you moved the distributor maybe ??
sounds like the timing's off or your starter just took a crap / bad connection , battery,starter etc ...
2011 GT Auto
Old 08-05-2011, 10:40 PM   #14
nickcap's Avatar
hey guys,
it starts now after messing with the new distributor cap but now it is smoking but it is white smoke idk if it is oil from putting the valve covers and intake back on also it is shaking (the car) like it wants to bog out but wont! is it my timing? please respond asap!!! im like freaking out ha
Old 08-06-2011, 12:08 AM   #15
hey guys,
White smoke is usually a sign of coolant consumption, but it could be from oil on the exhaust headers too.
Where is the white smoke coming from?
Did you mop up all of the coolant when you removed the intake and did you change your oil?
Did you set your timing?
Remember to remove the spout connector when setting the timing and to replace it after you were done?
Old 08-06-2011, 12:34 AM   #16
Sry if this has been asked but what year is ur car and do u still have the "stock engine" in it?
Hawk is offline   Reply With Quote
Old 08-06-2011, 01:08 AM   #17
hey guys,
Probably the timing
Old 08-06-2011, 03:58 AM   #18
Probably the timing
+1, also double check to make sure the plug wires are in the right firing order. It's an easily overlooked mistake.
Old 08-06-2011, 06:52 AM   #19
stampde's Avatar
Probably the timing
+3 , set the timing , do you know how ?
2011 GT Auto
Old 08-06-2011, 08:49 AM   #20
nickcap's Avatar
Umm Trojan the smoke is coming from the back of the engine and I didn't change the oil and I dint think I mopped up the coolant? And yea does anyone know the timing order for a 1995 mustang gt
Old 08-06-2011, 08:58 AM   #21
Beav's Avatar
You probably switched a couple wires..
1995 Ford Firing Orders
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 08-06-2011, 09:11 AM   #22
nickcap's Avatar
No I checked that everything is right
Old 08-06-2011, 09:39 AM   #23
Then more than likely it is just oil burning off the exhaust.
You should always change your oil when you remove the intake manifold because no matter how hard you try, coolant usually gets down into the oil pan.
The firing order is 13726548 in the counterclockwise direction from #1 plug wire terminal.
Old 08-06-2011, 09:43 AM   #24
Beav, don't trust those firing orders listed on that page.
I checked and found several of them to be wrong.
Old 08-06-2011, 09:45 AM   #25
nickcap's Avatar
Trojan do you know the timing for a 1995 mustang gt 5.0 ho...
Old 08-06-2011, 09:57 AM   #26
KELLY95's Avatar
10 before top dead center
Old 08-06-2011, 09:57 AM   #27
Firing order. 1-3-7-2-6-5-4-8
Stock timing is 10 degrees BTDC
Old 08-06-2011, 10:32 AM   #28
Did you put the pcv valve in the lower intake. If it's out it will smoke like crazy and run rough.
Old 08-06-2011, 11:01 AM   #29
nickcap's Avatar
I never messed with the lower intake but thanks I'm ping to set the timing an see if it helps thanks guys I'll let you know
---------- Post added at 05:01 PM ---------- Previous post was at 04:59 PM ----------
Oh and is it clockwise to higher and counter to lower and should I set it to 10 or higher
Old 08-06-2011, 03:32 PM   #30
[/COLOR]
Yes, clockwise is higher and vice versa. I would set it at 10 until you get the problem solved.
Old 08-06-2011, 05:49 PM   #31
nickcap's Avatar
EVERYONE IT WAS JUST A VACUUM LEAK I CAN'T BELIEVE IT thanks everyone for there time and advice thanks guys she runs beautifullllllll!!!
Old 08-06-2011, 07:06 PM   #32
U have a 95 gt thats cool i have a 94... F.Y.I. I hope ur not running regular gass in it its pre 98 and not good to run e85 mixed gas which all regular gas is now so i would recomend adjusting ur timing from ten deg of advance to 12 and run premo she will run WAY Nicer for u and if u have been running reg gas bye some fuel injector cleaner and run it threw a few tanks once ur timmings set b4 ur injectors get all pluged up with that garbage gas
---------- Post added at 05:06 PM ---------- Previous post was at 05:05 PM ----------
Oh ya good job figuring it out by the way
Old 08-06-2011, 07:35 PM   #33
Regular will run fine in his car. All grades of gas have 10% ethanol and e85 is 85%. The only reason to really run premium is if he has the supporting mods.
Old 08-06-2011, 07:45 PM   #34
nickcap's Avatar
Ha thanksssssssssssssssssssssssssssssssssssssssssss
Old 08-07-2011, 12:02 AM   #35
I never really thought of it but the first mods i did were to set her up for premo so meh to each his own i guess
05:54 AM
