302 to 307 - Mustang Evolution
Old 08-06-2011, 07:15 PM   #1
macmarine39's Avatar
302 to 307
What makes a 307? Is it just the bore? And what would that bore be? Or is it both bore and head chamber clearance?
macmarine39 is offline   Reply With Quote
Old 08-06-2011, 07:16 PM   #2
Las0mbra's Avatar
Bore or stroke...
Old 08-06-2011, 07:21 PM   #3
Good question, I'm not sure!
Old 08-06-2011, 07:25 PM   #4
Las0mbra's Avatar
Umm... I've heard of 306s... I think they're bored like .030 or .040 over...
---------- Post added at 08:25 PM ---------- Previous post was at 08:22 PM ----------
Checked it! 302 bored .030 over
http://www.allfordmustangs.com/forum...red-302-a.html
Old 08-06-2011, 07:32 PM   #5
Thank you, I appreciate your help. I have a friend of a friend selling this "307" engine with edelbrock performer heads and complete intake, with everything and ready to run with 50 k on the engine. How much would something like this be worth?
Old 08-06-2011, 07:38 PM   #6
Las0mbra's Avatar
Umm, honestly, I wouldn't know... You could probably post a thread with more info about the engine and get some responses there.
Old 08-07-2011, 08:46 AM   #7
Re: 302 to 307
How much does he want?
Actual worth price = As much as he can get - averaged with - as much or as little as you want to pay.
Look up prices on the parts he has in the engine, add some for assembly, then subtract an amount that's fair for usage.
Old 08-07-2011, 10:41 AM   #8
Titus Wadicus
svtlx's Avatar
Re: 302 to 307
306 is .30 over. 308 is .40 over ... And so on. The xtra c.i. Comes from the bore size only
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Boss 302 vs GT 5.0 poloka 2011-2014 Mustang GT 188 06-20-2011 04:08 PM
08:55 AM
