How bad did i screw up? - Mustang Evolution
Old 08-07-2011, 06:30 PM   #1
I'm in the middle of a 351 Windsor rebuild.
The only thing I planned on re-using were the stock pistons and rods.
I took the advice of a post online that said you could use oven cleaner to clean these parts up.
I now have a set of factory pistons with some spots where a coating has been removed.
Are these usable?
Boes462 is offline   Reply With Quote
Old 08-07-2011, 08:01 PM   #2
Re: How bad did i screw up?
Are these usable?
I don't know what the coating is, but oven cleaner will eat into aluminum which would be very bad if you intend on using the pistons again.
You will need to very closely check (any uncoated areas especially) for corrosion or pitting on any critical surfaces, such as the wrist pin contact area and piston ring grooves.
Old 08-08-2011, 08:19 AM   #3
stampde's Avatar
get new pistons / oven cleaner's deadly
2011 GT Auto
Old 08-08-2011, 09:06 AM   #4
wereKEV's Avatar
Oven cleaner is not good for engine parts I would go buy new pistons for safety reasons.
wereKEV is offline   Reply With Quote
Old 08-08-2011, 09:22 AM   #5
Tib
Tib's Avatar
It looks like it started to eat in at the corners. I would replace the pistons.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 08-08-2011, 11:51 AM   #6
nickcap's Avatar
Yea oven cleaner=not to good for engine parts, buy new pistons and rods if the rods are like that also! Your taking a chance for pieces of metal to fall into your engine, which can seize it which will lead you to pulling it out and rebuilding it, which would coat you more money... Pistons are much cheaper then rebuilding the engine
1995 Mustang GT Convertible!! (My Baby Monique) Ha
nickcap is offline   Reply With Quote
Old 08-10-2011, 07:34 PM   #7
Thanks for the advice. New pistons ordered.
Old 08-10-2011, 11:01 PM   #8
nickcap's Avatar
No prob!!! Better safe them sorry!! :thumbsup:
For Sale: Bad A** Sonic blue Terminator, Drag setup drusmith FYI Ads | Recently Listed 15 08-09-2011 07:18 AM
Bad luck... Blackedout Pre-2005 V6 Mustang 20 07-29-2011 07:50 AM
My 6 disc OEM CD player bad jjsg09 1996-2004 Mustang GT 18 07-13-2011 10:09 PM
01:09 PM
