Major AODE trans - Mustang Evolution
Old 08-09-2011, 08:31 AM   #1
Major AODE trans
I just swapped in a AODE I had bought that was rebuilt in place of my burnt up factory AODE. I put in a 3200 stall and everything went in fine but I fired it up and put it in reverse and the motor acted like it engaged but the car didnt move.. Same in every drive gear.. I need help please
94mustanggt5.0 is offline   Reply With Quote
Old 08-09-2011, 09:22 AM   #2
kickerofdoom's Avatar
They might of missed installing the gear pin. It's like a metal piece that picks the gears . When i did my own jmod I didn't put it in the right place so I could only move forward
Old 08-09-2011, 11:33 AM   #3
Where would the gear pin be located? I took the old AODE out and swapped everything over off of it to the new AODE
Old 08-09-2011, 01:44 PM   #4
Re: Major AODE trans
Did you fill the convertor with oil before you installed it?
Old 08-09-2011, 02:34 PM   #5
I did not fill the converter with oil before but wouldn't it filter through once i filled the tranny?
Old 08-09-2011, 03:02 PM   #6
Filling the transmission will not fill the convertor.
The pan/oil level is a lot lower than the inlet of the convertor.
The convertor gets its fluid supply from the transmission pump.
You may have damaged the convertor and possibly the transmission too.
They should have provided you with instructions?
Old 08-09-2011, 03:12 PM   #7
That's just what I wanted to hear .. So I should drop it and fill the converter with with oil then put it back in?
Old 08-09-2011, 03:58 PM   #8
Could it possibly be the pump?
Old 08-09-2011, 04:40 PM   #9
Maybe if you didn't run it very long and it didn't damage anything.
If you ran it very long then it may be pumped full by now.
Old 08-09-2011, 04:43 PM   #10
Anything is possible.
Drain the fluid into a clean container so you can maybe reuse it, then remove the pan and check for excessive metal particles.
There will likely be some metal, usually in the form of very, very small flakes and black dust from the clutches. Anything more than that would lead me to suspect serious damage.
Old 08-09-2011, 05:22 PM   #11
You need to drop the pan and make sure the rooster comb is engageing the manual valve on the valve body, if it is then you need to hook up a pressure gauge to the port on pass side of trans if you have no pressure then it's ether a bad pump or you didn't get the converter all the way in... I build automatics for a living, if it was rebuilt it should have new bands, sprags, etc, a bad over run clutch would do that aswell..
Make sure there is pressure before you do anything else
C4king is offline   Reply With Quote
Old 08-09-2011, 09:11 PM   #12
91gt's Avatar
C4king I got and aod trans and just had it rebuilt and now it doesn't shift out of second what could be some of the problems
91gt is offline   Reply With Quote
Old 08-09-2011, 10:08 PM   #13
I'm getting the pressure Gage tomorrow after work.. I wont know anything till tomorrow but I will let you guys know then. Thank you
Old 08-09-2011, 11:00 PM   #14
Post your question as a separate thread so it doesn't interrupt the flow of this thread please.
Old 08-09-2011, 11:07 PM   #15
And if there is pressure or isn't pressure?
Old 08-09-2011, 11:35 PM   #16
If there is pressure then the pump is working, but you will need to make sure the pressure is correct. Not sure what PSI is required.
If there is not pressure then the pump has failed or you have blown a seal or gasket.
Old 08-12-2011, 06:22 PM   #17
0 pressure in all gears. Gonna drop the tranny tomorrow and see if we can't find the problem
Old 08-12-2011, 08:10 PM   #18
Man that sux.
Good luck.
Old 08-12-2011, 09:18 PM   #19
Yea thanks haha Ima try swapping the epc solenoid and make sure the pump is engaging
Trans 91gt 1979-1995 Mustang GT 3 08-03-2011 01:39 PM
01:30 PM
