Air Vent Problem - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 08-16-2011, 08:15 PM   #1
crkmonzo's Avatar
crkmonzo is unknown around these parts
Exclamation Air Vent Problem
The air/heat will only blow out on the feet and defrost vents, and when it rains water leaks in when you have the air on. what could this possibly be?
crkmonzo is offline
Old 08-16-2011, 08:25 PM   #2
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
As for where it's blowing, either your switch is bad or your vacuum line is disconnected. Not sure about the water unless something is directing water into your fresh air vent outside.
93slowstang is offline
Old 08-16-2011, 08:28 PM   #3
Senior Member
Trojan Horse is just getting started.
Re: Air Vent Problem
Your switch is not working or you have something in the system blocking the air flow divertor plate.
There is a drain in the heater core, A/C core housing that drains off the condensation that forms when you run the A/C. It is probably plugged up.
Trojan Horse is offline
Old 08-16-2011, 09:07 PM   #4
crkmonzo's Avatar
that seems to make the most sense, thank you
crkmonzo is offline
Old 08-16-2011, 09:16 PM   #5
Senior Member
You are welcome.
Hope you find your problem.
Old 08-16-2011, 09:18 PM   #6
crkmonzo's Avatar
what would be the way to find whats plugging it, taking the whole dash apart?
crkmonzo is offline
Old 08-16-2011, 10:12 PM   #7
Otlaw80's Avatar
Otlaw80 is unknown around these parts
If you can get it up on a lift, you will be able to see the drain hole/hose. Unbend a clothes hanger or a piece of sturdy bailing wire and stick it up the hole....
Otlaw80 is offline
Old 08-17-2011, 10:52 AM   #8
wereKEV's Avatar
wereKEV is unknown around these parts
It culd also be your cabin filter is clogged up and needs to be replaced.
wereKEV is offline
Old 08-17-2011, 11:09 AM   #9
Moderator
I don't believe we have cabin filters on the foxes.
Old 08-17-2011, 11:11 AM   #10
wereKEV's Avatar
sorry my bad.
wereKEV is offline
Old 08-17-2011, 11:15 AM   #11
Moderator
sorry my bad.
I thought I had one till I tried to find a replacement, I was baffled that there isn't one.
Old 08-17-2011, 04:40 PM   #12
crkmonzo's Avatar
so are yall saying that unplugging the drain hose would solve both problems?
crkmonzo is offline
Old 08-17-2011, 04:44 PM   #13
Moderator
It should at least solve the water problem if it's stopped up.
Old 08-17-2011, 04:45 PM   #14
crkmonzo's Avatar
ok thanks because it is really annoying when its raining out and all the sudden your boots and socks are wet because its just dripping away from under the dash lol
crkmonzo is offline
Old 08-17-2011, 04:48 PM   #15
Moderator
You need to check your vacuum line that comes off the tree and into the car. It should be a little black one. Check it under the dash to where it meets the vacuum plugs.
---------- Post added at 05:48 PM ---------- Previous post was at 05:46 PM ----------
If the drain isn't clogged you might have to pull the cowl of to get to the fresh air vent and check that.
Old 08-17-2011, 04:51 PM   #16
crkmonzo's Avatar
ok and when i check that, what would i check to see? sorry i am asking a lot of questions but like a said its my first mustang so i am new to all this. i am used to having big lifted mud trucks were it really dont matter lol
crkmonzo is offline
Old 08-17-2011, 05:26 PM   #17
Moderator
Lol, better to ask then try and guess. You should see a vent back against the firewall on the passenger side if I remember right. It's hard to miss.
Old 08-17-2011, 06:37 PM   #18
crkmonzo's Avatar
ok thanks man
crkmonzo is offline
Closed Thread
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
Vacuum lines coming from passenger fender well.? Otlaw80 1979-1995 Mustang GT 3 08-15-2011 07:01 AM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
Air extractor grilles theopenroad Classic Mustangs 0 07-26-2011 04:45 AM
02:11 PM
