I've heard the intake flowed pretty good and lots of people liked them but does anyone know about a lot about them and about how much I should ask for if I sale it/trade it?
The GT40 intake is lighter and it will run a bit cooler due to the exposed tubes which allow airflow and has more surface area exposed, but it is also said to be louder as the air passes through the tubes because it lacks the thickness and sound dampening properties of the cast intakes. The lower intake is the bottleneck on the GT40 and Cobra intakes. It would be nice to see a comparison with a ported lower on each upper manifold.
As you can see there is not much difference between the GT40, Cobra and Explorer intake manifolds. The GT40 however looks much better IMO.
I have seen prices ranging from a low of $250 to a high of $600. It would depend upon the condition of your intake and how bad someone else wants it I suppose. Are you talking upper and lower or just upper?
Upper and lower but I don't have the upper cover for it. The previous owner painted the plentum box to color match the car so I need to figure out how to get the paint off without messing up the original finish.
I would like to trade it for a trick flow set up or the like but not sure if it's worth it for someone to trade?
---------- Post added at 02:50 AM ---------- Previous post was at 02:42 AM ----------
Wow...the power curve is almost the exact same for all three of them, just a little better torque curve for the tubed intake but not enough to be able to feel it!
So I guess it would just depend on the looks of it, if someone would be willing to trade.
Thanks Trojan, always good information!
if you look at all those numbers on those intakes ,they are all within a few horse of each other ,thats because they are basically identical ,with variations in casting that skew the numbers just a bit from each other ....... the advantage of the gt40 is the cooler air ,as Trojanhorse said ........ but it also has a disadvantage because you can't port the upper ,there's no material there to do it , but you can port the upper plenum's on the other 2 ...............
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
