Smog pump delete - Mustang Evolution
Old 08-22-2011, 07:55 PM   #1
Filibuster
Smog pump delete
I have underdrive pulleys with an a/c delete,but still have the smog pump..im goin to get rid of that as well and was wonderin the best way to plug the the back of the heads when I remove the tube?..
XXSTEVEO66 is offline   Reply With Quote
Old 08-22-2011, 08:03 PM   #2
Stang.racr's Avatar
You can get it welded off, I just kept the smog pump on and got a shorter belt that bypassed it on mine.
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 08-22-2011, 08:12 PM   #3
Re: Smog pump delete
Ditto. Works just fine.
Old 08-22-2011, 08:13 PM   #4
Filibuster
Cool...i suck at welding,but thats what friends are for!...i think im going to get the delete pulley I like the extra room in the engine bay!!..
But just for kicks do you know the belt # you're running?...might do that for now...
Old 08-22-2011, 08:27 PM   #5
Stang.racr's Avatar
Trojan horse has some belt size charts, I went and looked but didn't see a number. You can get one of them floppy sewing measure tapes at walmart for like a buck, at 20ish bucks a belt you will wanna get it right the first time lol, you can bypass and take all the other smog crap off, that is the sucky part though, choosing belts afterwords. I have no rubbing issues neither. I run underdrive pulleys and also threw on a sn95 alternator that had a bigger pulley.
Old 08-22-2011, 08:28 PM   #6
I'm not 100% sure, but if I remember correctly two 5/8" x 11 thd short bolts will seal up the holes in the heads.
Old 08-22-2011, 08:40 PM   #7
Filibuster
Thanks guys ill look into it..
Old 08-22-2011, 09:21 PM   #8
Otlaw80's Avatar
That is correct! Just put some in mine a few weeks ago.
Old 08-22-2011, 11:08 PM   #9
5.0 Belt Lengths
1985-1993 Mustangs
These are recommended belt lengths for stock pulleys on 85-93 5.0 Mustangs.
Name:	5.0 Belt Lengths..jpg
Old 08-23-2011, 10:46 AM   #10
Otlaw80's Avatar
Thanx Trojan I've been looking for that diagram.
Old 08-23-2011, 11:45 AM   #11
You're welcome.
Old 08-23-2011, 03:18 PM   #12
Filibuster
5.0 Belt Lengths
1985-1993 Mustangs
Nice!...by the looks of that ill just plug the heads with bolts,remove the smog pump all the plumbing,and just run the shorter belt!..
Save myself a few $$$ on the delete pulley!...
Think water pump is gone? Whiterocknotch 1979-1995 Mustang GT 11 09-04-2011 08:39 AM
Convertible Top Pump with Metal Shavings Xexyz General Mustang Discussion 1 08-12-2011 06:26 AM
PPRV delete, wish me luck....! drusmith Other Special Edition 31 08-05-2011 10:00 PM
Powersteering pump jhagan1980 1979-1995 Mustang GT 5 07-06-2011 09:05 PM
Water pump pulley Carlos92 Pre-2005 V6 Mustang 6 07-04-2011 07:55 PM
09:19 AM
