Mph guage - Mustang Evolution
Old 08-22-2011, 08:50 PM   #1
Mph guage
My dash says my speed is say 50mph but.im only going 40mph..im 10mph off..any way to fix that? If not ill.just leave it
94GTx306 is offline   Reply With Quote
Old 08-22-2011, 10:05 PM   #2
SleepingStang's Avatar
If it is mechanical then you can GENTLY pry the need off the post and while pacing a friend at a predetermined speed or going off of GPS speed place it back on the post at the correct speed. If the speed is off due to a bad gear or incorrect gear then that would need to be changed. This may not be the safest way but it is a way. If the speedo is electronic I think you'll need a tuner to adjust the speed.
SleepingStang is offline   Reply With Quote
Old 08-22-2011, 10:49 PM   #3
Re: Mph guage
If you don't have the factory gears in the rearend you will need to change the speedo gear.
Old 08-23-2011, 07:13 AM   #4
I do have diff gears on it..ok guys thanks
Old 08-23-2011, 12:15 PM   #5
Re: Mph guage
Speedo Gear Chart
Name:	Ford Speedo Gear Chart.jpg
04:11 AM
