95 cobra tach - Mustang Evolution
Old 08-23-2011, 03:14 PM   #1
jhagan1980's Avatar
95 cobra tach
1-How would I go about testing the tach to see if it's bad? 2-How would I go about changing it out if it is? It usually stays at 0 but sometimes will work just fine or will work but be way off. I have the gauge cluster out but not sure if there is a test I can do?
jhagan1980 is offline   Reply With Quote
Old 08-23-2011, 07:36 PM   #2
Re: 95 cobra tach
There are no tests that you can do at home that will verify if the tach is good or bad. It would have to be sent to a repair shop and the cost for testing and repair usually exceeds the cost of a new tach.
It sounds like you have an intermittant connection somewheres.
Check your wiring and connectors.
Old 08-24-2011, 03:20 PM   #3
jhagan1980's Avatar
If I buy another gauge cluster are the tachs interchangeable?
Old 08-24-2011, 03:26 PM   #4
Re: 95 cobra tach
Yes, out of the 94-95 models they are.
Not sure about the 96-98 as the modular engine may use a different triggering system.
Did your wires and connections check out ok?
Old 08-24-2011, 03:34 PM   #5
jhagan1980's Avatar
Haven't ran them down yet. Im gonna try and do that tonight. I was just seeing if they could be switched out if it came to that.
Old 08-24-2011, 05:32 PM   #6
jwhayne0001's Avatar
Mines parked for a few days if you can easily remove the IC withoutbreaking it you try mine....
jwhayne0001 is offline   Reply With Quote
Old 08-24-2011, 06:52 PM   #7
jhagan1980's Avatar
Alright here's the deal. Took jwhayne's cluster out of his cobra and plugged it up and it worked just fine. Soooo, what cars are compatible to swap tachs with? I know it has to be a v8 but does it have to be a mustang? It will be much easier to find one at a pull and pay place if it's not out of a mustang.
Old 08-24-2011, 09:51 PM   #8
Re: 95 cobra tach
It will have to be a V8 Mustang, 94-95.
The gauges and cluster are "custom" to each car and I doubt any other V8 car will have the same tach.
Old 08-25-2011, 10:56 AM   #9
jhagan1980's Avatar
I know I'm asking alot of questions but I'm trying to get this figured out. If I buy another cluster will I be able to take just the tach off and put it on my cluster? The speedo and tach are built together along with the odometer. I'm not wanting to lie about mileage or increase my mileage by changing out the speedo and tach.
Old 08-25-2011, 05:53 PM   #10
Re: 95 cobra tach
Without seeing or knowing how it is put together, I'm not sure if you can or cannot. If the tach can be separated from the speedo, then yes you should be able to do that.
Old 08-25-2011, 06:48 PM   #11
jhagan1980's Avatar
I've taken it apart and it can be changed out. The problem is finding one.
Old 08-25-2011, 06:57 PM   #12
Re: 95 cobra tach
Attachment 30922
Check out the clusters here - Florida 50 maybe they have something you like or can use.
Old 08-26-2011, 11:03 AM   #13
jhagan1980's Avatar
A tach out of a 96 t-bird will work, mates up perfect.
96 SVT Cobra appears Superchip is bad opinions on my options please Spiney SVT Mustang 15 11-07-2011 07:34 AM
Cobra Pricing Opinions... 2008Shelby SVT Mustang 25 09-04-2011 03:49 AM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
96 SVT Cobra Tuner Chip ECM questions ? Spiney SVT Mustang 0 08-05-2011 12:43 AM
Just bought an 01 cobra....suggestions/headsup rinfield2004 SVT Mustang 32 07-12-2011 12:28 PM
06:22 AM
