Idler pulley - Mustang Evolution
Old 08-25-2011, 12:10 PM   #1
jwhayne0001's Avatar
Idler pulley
Ive found the source of my grinding/growling noise, the ford dealer i work at priced an idler pulley to me at a whopping 400 dollars DISCOUNT price, talked to one of the older mechanics here, he said they are bad about wearing out the shaft and it was the whole bracket and pulley, autozone has just the pulley for 20 bucks, anyone ever just replaced the pulley, oh and its the one on the top in the middle on a 1995 5.0L thanks
jwhayne0001 is offline   Reply With Quote
Old 08-25-2011, 12:14 PM   #2
crkmonzo's Avatar
Re: Idler pulley
i have bought the whole bracket from autozone, if you do buy one from their make sure it has the warrenty because the spring went bad on my brand new one from their, couple buddies had the same problem, i would say it was better then 400 dollers though.
crkmonzo is offline   Reply With Quote
Old 08-25-2011, 12:18 PM   #3
I wonder if i can get away with just a pulley?
Old 08-25-2011, 12:25 PM   #4
crkmonzo's Avatar
Re: Idler pulley
you can try, just check to see how much play is in the bracket when their is no tension on it. i went through a huge problem with one of my pulley systems and bought pretty much a whole new pulley system because it started off with a squeking noise from the belt, then i ended up braking 4 belts in 4 days, i had two problems 1 the new idler pulley bracket was bad and their was a missing bolt on the powersteering pump bracket missing and the torque was ripping the belts off and shreeding them.
Old 08-25-2011, 12:50 PM   #5
How much, ball park, was that bracket and all from autozone? And how big of a pain was it to install?
Old 08-25-2011, 12:55 PM   #6
crkmonzo's Avatar
Re: Idler pulley
i wanna say the bracket and pulley is around 50 bucks and it aint to bad of a job, just take the belt off and undo the bracket.
Old 08-25-2011, 02:00 PM   #7
Well the pulley they gave me ia metal and the stock is plastic, no big deal but, stock has 2 ridges on both sides of the pulley and is smooth in between but the new one is completly smooth, is that a problem?
Old 08-25-2011, 02:16 PM   #8
crkmonzo's Avatar
Re: Idler pulley
shouldnt be i beleive they do make that change, make sure how ever they gave you the right pulley
Old 08-25-2011, 02:23 PM   #9
Brett Greene's Avatar
Idler pulley and Harmonic Balencer all go all the older 5.0s I replaced the idler pulley more than once.
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 08-25-2011, 02:56 PM   #10
crkmonzo's Avatar
Re: Idler pulley
ya, ive seen it alot to, the rubber ring on the back of the harmonic balancer will be completely gone.
Old 08-25-2011, 04:48 PM   #11
Thanks guys put the pulley on and its golden!
underdrive pulley kickerofdoom Pre-2005 V6 Mustang 6 08-09-2011 03:57 PM
UD pulley kits t0t4lbl4ck0ut General Car Discussion 3 07-09-2011 09:02 AM
2010 pulley upgrade Gibby Saleen & SMS Mustang 13 07-09-2011 12:55 AM
Water pump pulley Carlos92 Pre-2005 V6 Mustang 6 07-04-2011 07:55 PM
09:17 PM
