Hot CAI - Mustang Evolution
Old 08-26-2011, 10:17 PM   #1
Filibuster
Hot CAI
So I already know how hot my BBK CAI gets when the engine is hot...
So it should be called a hot air intake!!...
K&N has plastic should I change?..
XXSTEVEO66 is offline   Reply With Quote
Old 08-26-2011, 10:18 PM   #2
Re: Hot CAI
I wouldn't.
If it gets very hot, it might melt or deform.
Is there anything you can do to block off any heat sources?
Old 08-26-2011, 10:29 PM   #3
Filibuster
Originally Posted by Trojan Horse
I wouldn't.
Nah...its just as hot as the next guys CAI...but im just saying let your fox warm up then feel the intake....its f@$kin warm!!...making me think not so cold intake!!..the stock plastic is restrictive but it never gets warm!...unless you have the ice pack between runs is it really CAI?...
Old 08-26-2011, 10:43 PM   #4
Re: Hot CAI
I honestly don't know if that is a good idea or not.
The metal may feel hotter, but if it is aluminum it will shed or disperse the heat faster than plastic, so it may "feel" hotter.
If that wasn't the case, then they would make heat sinks and coolers out of plastic rather than aluminum.
Old 08-26-2011, 11:00 PM   #5
Filibuster
Nice reply!..
I love good answers to good questions,and I always find them here!!..i love this forum!!..
I do know alot when it comes to cars,but I dont know everthing and its awesome to always have a second opinion!..
Old 08-26-2011, 11:19 PM   #6
Re: Hot CAI
Nice reply!..
We try our best.
The addition of your knowledge to the forums is appreciated too.
It is nice to have someone appreciate the knowledge and efforts.
We don't know everything, but we will always try to find an answer for you.
Old 08-27-2011, 07:48 AM   #7
Titus Wadicus
svtlx's Avatar
Re: Hot CAI
some of us 'ol school guys do this. buy the super cheap ebay (fender well mount) cai, then with the money u saved get'n your chinese cai... purchase some thermal heat wrap (similar to ace bandage) from jegs, summit, or even ebay again. this will save you lotsa money, very functional. however, u wont have that shiny cai tube anymore.
just my 2 cents.....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 08-28-2011, 10:51 AM   #8
89white GT's Avatar
Region: Iowa
How hot does your motor run on average?
89white GT is offline   Reply With Quote
Old 08-28-2011, 11:23 AM   #9
Filibuster
Between 190°-210° depending on my left foot!...
Its really nothing im too worried about just kinda thought having a CAI might defeat the purpose a lil bit at operating temp with warm pipes!..
Old 08-28-2011, 12:25 PM   #10
Stang.racr's Avatar
Like they said, I run a plastic one cause it's what came on mine, they disperse alot better, you can buy header wrap to cool your engine bay down
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 08-28-2011, 12:50 PM   #11
89white GT's Avatar
Region: Iowa
I put a 93 cobra water pump pulley and 160 degree thermostat in mine and my motor doesn't get over 200 degrees
Old 08-28-2011, 12:58 PM   #12
Stang.racr's Avatar
190-210 depending on your left foot? Lol
Old 08-28-2011, 01:12 PM   #13
Filibuster
Ha!...whoops!...yeah I remember my first beer :/ ......my RIGHT foot!!!...im retarded...
cai
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
Best CAI?? 11stangGT 2011-2014 Mustang GT 29 07-17-2011 12:16 PM
I need a cheap CAI!!? nickcap 1979-1995 Mustang GT 7 07-16-2011 04:43 AM
CAI problem MustangGT02 1996-2004 Mustang GT 5 07-15-2011 01:50 PM
94 mustang gt is running hot!!! 94 GT 1979-1995 Mustang GT 20 07-01-2011 02:45 PM
04:52 AM
