Cam in my 1994 gt - Mustang Evolution
Old 08-27-2011, 09:20 AM   #1
FordRacer_51's Avatar
Cam in my 1994 gt
I'm wanting to put an e-303 ford racing cam in my 94 gt do I have to mod the ecu???? And Is the stock 5.0 H.O in it have hydraulic rolled litters in it??
FordRacer_51 is offline   Reply With Quote
Old 08-27-2011, 11:20 AM   #2
LOWCOP's Avatar
not sure about the ecu but yes your motor is a hydro roller motor
LOWCOP is offline   Reply With Quote
Old 08-27-2011, 11:44 AM   #3
Ok thanks I wanna cam it but I don't know if it mess up the ecu I've heard both yes and no??
Old 08-27-2011, 11:49 AM   #4
LOWCOP's Avatar
I know in the 87-93 it will work fine with the ecu but they say the 94-95 has a very finicky ecu. the alphabet cams are "supposed" to be computer friendly but we all know how that works out lol
Old 08-27-2011, 12:51 PM   #5
Yea lol I was going to try a E-303??
Old 08-27-2011, 12:54 PM   #6
LOWCOP's Avatar
the "e" cam is a good one
Old 08-27-2011, 01:04 PM   #7
I'm going order it from AM in a few weeks.
Old 08-27-2011, 01:07 PM   #8
Standered or auto? If standerd e303 will work fine with out ecu upgrade(tune) if auto look at f303 (no tune to ecu) but vise versa if auto and putting e303 in how ever f303 requires 2500 stallconverter and dome head work
Hawk is offline   Reply With Quote
Old 08-27-2011, 01:38 PM   #9
It's auto
Old 08-27-2011, 02:29 PM   #10
So if I go with the E cam I will have to do a tune??
Old 08-27-2011, 06:24 PM   #11
Yes u will then
---------- Post added at 04:24 PM ---------- Previous post was at 04:02 PM ----------
The f303 cam was designed for the auto so u wouldnt have to upgrade ur ecu with that cam how ever as i said b4 u need a 2500stall converter to run the f303 cam and better valve springs ull also have to check piston to valve clearence with the f303 (recomend doing the valve springs and checking ur cleariences with ether the e303 or f303 but for sure with the f303) but u also need to tune ur ecu in an auto to run the e cam(a stall converter wouldnt hurt ether) but to do it right i would just run the f303 cam abd b done with it (with exhaust msd ignition and a good ram air or cold air filter should b good for 325hp or more bepending on weatger or not u tune and the quality of the tune
Old 08-27-2011, 07:12 PM   #12
So u think 325 with cai full exhaust using e303
tbonestang is offline   Reply With Quote
Old 08-27-2011, 07:27 PM   #13
At the fly prolly 280s at the wheel but what other mods u got?
---------- Post added at 05:27 PM ---------- Previous post was at 05:25 PM ----------
Im not sure with the e 303 i was going off the f303
Old 08-27-2011, 07:40 PM   #14
The f is a little more radical alittle more lift.
Old 08-27-2011, 07:42 PM   #15
Just back my gt 40 intake , Already done flow tech headers underpulley ac del pulley no cats hpipe flowtech mufflers and sct tuner oh yeah cai so what's ur guess
Old 08-27-2011, 07:48 PM   #16
Best guess around 350 fwhp how close am i?
---------- Post added at 05:48 PM ---------- Previous post was at 05:47 PM ----------
Sry u have a cam or no?
Old 08-27-2011, 08:12 PM   #17
No cam yet coming in the winter with new heads but not sure which yet gotta figure out the best bang for the buck
Old 08-27-2011, 08:37 PM   #18
I've heard great things about the E-303. Depending on what kinda piston work you wanted to do?? And how much lift you want
Old 08-27-2011, 08:49 PM   #19
No cam id say ur pritty close to what 300 hp then have u dynoed her yet?
---------- Post added at 06:49 PM ---------- Previous post was at 06:46 PM ----------
With the auto u really need the extra kick the f303 delivers though. basicly makes up for being 1 gear short the 5 speed std tranny.
Old 08-27-2011, 08:51 PM   #20
I would go with the f I just really not wanting to do the pistons
---------- Post added at 10:51 PM ---------- Previous post was at 10:50 PM ----------
Not right awAy anywAy
Old 08-27-2011, 08:59 PM   #21
T5 and no dyno yet not till cam and heads get done
Old 08-27-2011, 10:41 PM   #22
93slowstang's Avatar
You can probably get away with the F cam with your stock heads. It's not all about the lift of the cam as lobe separation plays a big part too
---------- Post added at 11:41 PM ---------- Previous post was at 11:37 PM ----------
Originally Posted by Hawk
Yes u will then
The only somewhat acceptable cam for the auto is the E cam. It's recommended to use a high stall converter on both, as well as a tune.
Old 08-27-2011, 10:56 PM   #23
Funny when i talked with ford racing directly they told me the f was the one made for the auto annd all the ford cam source books ive read say right next to the f303 in brackets (recomended for automatic transmission) so hey maybe i got diffrent sources i dont know but even all the engine shops between kelowna and vancouver say f303 is for the auto so ask around i guess but for me its not really worth the work buy a 351 w and build a little 7l strocker then ur talking real power!
Old 08-28-2011, 05:52 AM   #24
Really because even in their catalog it's recommended that the f cam be used with a manual. Every site says the same thing. Maybe you need to re-read those sources. I do agree about building up a 351, more reward with the effort.
http://www.latemodelrestoration.com/...oller-Camshaft
http://www.fordracingparts.com/parts...tKeyField=2029
---------- Post added at 06:52 AM ---------- Previous post was at 06:49 AM ----------
The cam that seems to have the least issues with the ecu is the steeda #19. I would check that one out too.
Old 08-30-2011, 10:16 AM   #25
WhiteCobra94's Avatar
I have a 94 5.0, and when it comes to picking a cam for the 94-95 mustangs, the closer your degree lobe on a cam is to 114 degrees is better and less tuning , the e-303 is 110 degree lobe , I went with trick flow stage one cam which has a 112 degree lobe. But if your gonna pick the F-303 the power range is 1500-6500 rpm on them just make sure your heads and intake match that power range!
Old 08-30-2011, 05:30 PM   #26
What if I when with the e??
Old 08-30-2011, 05:38 PM   #27
The e-303 is fine if your staying in the idle to 5500rpm range,.. you will just need a tune for your car to run smooth!!! Personally I'd go with the TFS Stage 1 cam! But you can't go wrong either way!
Old 08-30-2011, 06:05 PM   #28
I still need a tune for the trick flow stage 1 right
Old 08-30-2011, 06:13 PM   #29
You would get the most out of any cam by having it tuned. You may not need it for that one, but I would recommend getting one. Your car will run better with it.
Old 08-30-2011, 06:24 PM   #30
Can I buy the sct flash tuner and have them send me a tune for what ever cam I do get??
Old 08-30-2011, 06:34 PM   #31
Yup you sure can!!
Old 08-30-2011, 06:41 PM   #32
Originally Posted by WhiteCobra94
Yup you sure can!!
Didn't think a flash tuner would work on pre 96 vehicles.
Old 08-30-2011, 06:44 PM   #33
AM sells a flash programmer for a 94-95. Pretty sure the plug in is under the driver side dash near the center console
Old 08-30-2011, 06:50 PM   #34
The only thing I see for the 94-95 is the eliminator chip.
Old 08-30-2011, 06:57 PM   #35
Y
---------- Post added at 06:57 PM ---------- Previous post was at 06:55 PM ----------
Sorry about that , the 4-bank eliminator chip from sct, it's $279 I think!!! But you can get a dyno tune with custom chip for $460-$600 depending on who you go too!!
Selling the GT killer The Darkside Mustangs for Sale and Wanted 24 10-18-2011 09:36 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
Cam Jesse Bach General Car Discussion 2 08-01-2011 01:37 PM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
03:57 PM
