Power adder - Mustang Evolution
Old 08-27-2011, 10:41 PM   #1
Mean green 91's Avatar
Power adder
Have a 1993 lightning motor in my 1991 GT looking for a good power adder. I priced a turbonetics turbo kit and didn't see too many reviews but does anyone know about them?
Mean green 91 is offline   Reply With Quote
Old 08-27-2011, 10:51 PM   #2
Re: Power adder
Check this post for ideas - Superchargers & Turbos
Old 08-27-2011, 11:19 PM   #3
Thanks now I found something I like in this post. Plus I found a Paxton super charger for 800.00 for the kit. Will post pics when I get it done step by step. Trojan horse
Old 08-28-2011, 12:40 AM   #4
Re: Power adder
That would be great!
Good find on your Paxton.
I found my Paxton Novi 2000 for half price, but it was still almost 3x times that price.
Old 08-28-2011, 08:05 AM   #5
I've been searching for almost a year now everyday so I think I'm going with the Paxton super charger. Just hope it doesn't sell before I can get the money. Another question for you don't know if the kit has injectors with it so what would be a good fit for 8lbs of boost? I already have 24lb injectors
Old 08-28-2011, 12:26 PM   #6
Titus Wadicus
svtlx's Avatar
Re: Power adder
wut size cam do u have? heads... valve size and cumbustion chamber size
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 08-28-2011, 12:37 PM   #7
The heads are GT 40 factory from a ford lightning. I'm not sure what cam is in it. The whole motor was rebuilt when I bought it.
Old 08-28-2011, 12:44 PM   #8
Titus Wadicus
svtlx's Avatar
Re: Power adder
the cumbustion chambers are small on those heads. so ur cam isnt much bigger than the .529 lift range. i am gonna say a set of 30lbs. should be fine. you will have room to grow like maybe 14-15psi of boost. but you will pretty much be at your limit as far as not having to get a tune.
keep your timing at 10 degrees advance, i dont recommend bumping up to 12, stay at 10 so u dont shatter a piston.
do not run an fmu with the set-up, u will be fine without it.
Old 08-28-2011, 12:56 PM   #9
Ok thanks! This website has been amazing.
Old 08-28-2011, 01:03 PM   #10
Titus Wadicus
svtlx's Avatar
Re: Power adder
ur welcome
Drivers side power mirror needed?! nickcap Mustang Parts for Sale and Wanted 3 08-29-2011 12:49 AM
Ditching power steering? Stang.racr 1979-1995 Mustang GT 4 08-24-2011 02:36 PM
how to fix power loss? austinknoll General Mustang Discussion 8 07-26-2011 10:49 PM
Voiding the Power train warranty dailey 2011-2014 Mustang GT 5 07-10-2011 02:31 PM
Ford Racing Power Pack MALS Marine 2005-2010 V6 Mustang 7 06-30-2011 09:07 PM
06:55 PM
