Mustang5.0 supercharged tuning qustion help plz - Mustang Evolution
Old 08-28-2011, 12:55 PM   #1
Fox5.0's Avatar
I bought the car with supercharger on it then blew the head gasket rebuilt top end with over sized metal layers head gasket felpro I put svo aluminum 64cc heads f303 cam 255 walbro with vortech inline boost retarded Box 24# injectors with cl Maf don't have 700 for a tune don't wana blow my head gasket again can use charger with out a tune or fmu And be safe for engine thank you
Fox5.0 is offline   Reply With Quote
Old 08-28-2011, 01:02 PM   #2
Titus Wadicus
svtlx's Avatar
Re: Mustang5.0 supercharged tuning qustion help plz
u need 30lbs injectors... prolly dont need the btm box, wut is ur timing set at? and u prolly need to get rid of the fmu when u jump up to 30's. most importantly, how much boost u running? u got too much cam for 24's under any boost level to b honest with u.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 08-28-2011, 01:19 PM   #3
Fox5.0's Avatar
ReAlly I have 42# in a box just haven used them heard ecu cant handle them and I already junked the fmu timing set at 10 so I can run it with out. Tune? And no fmu safely
---------- Post added at 11:19 AM ---------- Previous post was at 11:14 AM ----------
Oh Ya I have 10# pulley and a 6# pulley was going to start with the 6 thank you for reply man
Old 08-28-2011, 01:31 PM   #4
Titus Wadicus
svtlx's Avatar
6lbs pulley is ok for a stock cam with those heads. your maxed out with only 24's, 6lbs pulley, and cam. ur running outa fuel midway through your rpm range which is most likely y u blew a head gasket (it got hot as fuk in the cylinder, with no fuel to cool it down).
42's are waaay too lrge to run without a tune.
if u get 30's u will be fine, and u can run your 10lbs pulley. it should have u somewhere in the 450-465rwhp range.
u can run this set-up without a tune, btm, or fmu fine.
Old 08-28-2011, 01:40 PM   #5
Fox5.0's Avatar
If I retarded the timing can I run 24# injectors and ur car is sweet man are u using a tune basically I wana use my set up with super charger don't really care if I have crazy hp just want to play with it lol
Old 08-28-2011, 01:49 PM   #6
Titus Wadicus
svtlx's Avatar
ty, and no. if u run less than 10 degress the computer isnt gonna like it and your gonna create other issues. when u run boost, u multiply the copression in the cylinder over stock/static compression ratio. u need fuel to cool down the cylinders to stave off detination. the more boost u run, the more fuel u need.
example. 9.5:1 in a e7 head will ramp up to 17.1:1 with around 11-12psi of boost. pulling back the timing is only gonna help up to a certain point. the xtra compression makes heat, u gotta have fuel to cool down the cylinder. i hope wut i said makes sense.
there is actualy a slide chart to show static compression increase per pound of boost, but i cant remember wut i did with it.
Old 08-28-2011, 01:55 PM   #7
Fox5.0's Avatar
Ya u make sense man any way to run charger how it is? Don't really want need that much hp Ty again for your help
Old 08-28-2011, 02:00 PM   #8
Titus Wadicus
svtlx's Avatar
if u had stock heads and or stock cam u could prolly get away with it. u got too much motor for 24's on boost. try ebay or junk yard for sum 30's tbird supercoupe (not turbo coup) come with 30's
Old 08-28-2011, 02:36 PM   #9
Don't forget you will also need a MAF sized for the injectors you will be using.
11:03 AM
