Rear seat delete - Mustang Evolution
Old 08-28-2011, 06:54 PM   #1
351mustang's Avatar
Rear seat delete
Has anyone done it? If so how hard was it I'm thinking about it to place a sub and amp under the space it creates.
351mustang is offline   Reply With Quote
Old 08-28-2011, 07:09 PM   #2
Filibuster
I have the rear seat delete,but unfortunatly I didn't do it...but I cant imagine it taking 1 person too long at all!...i personally love the look!...i think it would look nice with the addition of some sounds!!..
XXSTEVEO66 is offline   Reply With Quote
Old 08-28-2011, 07:24 PM   #3
351mustang's Avatar
Well I read late resto site looks like it's only for coupes and verts
Old 08-28-2011, 07:43 PM   #4
Filibuster
Thats odd cause I have a hatch?..but like I said I didnt install it so im not sure how they did it?..
Old 08-28-2011, 08:33 PM   #5
Jettin Stang's Avatar
I did it to mite n put my amps there n I'm working on putting a bar there to hook my harnesses to
Jettin Stang is offline   Reply With Quote
Old 08-28-2011, 08:33 PM   #6
93slowstang's Avatar
Heres one
http://www.americanmuscle.com/hatchb...lete-gray.html
Old 08-28-2011, 08:54 PM   #7
Re: Rear seat delete
I've not done mine yet, but they are not hard to do.
I plan on fabbing and fitting mine from cardboard first, then using the cardboard for a template to cut out the aluminum I plan to use. I'm using aluminum for strength and weight. I can have it bead rolled to strengthen the plate and cut down on vibration and noise.
If you are wanting to install a high powered stereo system you may want to use something a bit thicker and heavier than the standard 1/8" to 1/4" wood or composite board materials to prevent rattling, vibrating and to help direct the sound.
Old 08-28-2011, 09:06 PM   #8
351mustang's Avatar
Good find 93slow and Trojan I'm just doing one 10 just for a little bass
Old 08-29-2011, 09:57 AM   #9
Use 1/2" medium density fiberboard to make it
Old 08-29-2011, 10:09 AM   #10
Something to consider is whether or not you want or need the rear bulkhead covered.
I do, because of battery relocation and other reasons.
Example: Bulkhead Cover
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
03 Stang Rear Blacked Out!? stangiusmaximus Mustang Paint, Appearance & Detailing 4 08-29-2011 06:30 AM
02 shutter felt in rear axel fpierce General Mustang Discussion 12 08-14-2011 10:28 AM
Rear wheel and tire size poloka 2011-2014 Mustang GT 11 07-27-2011 07:44 AM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
05:44 AM
