95 GT questions - Page 2 - Mustang Evolution
Old 10-31-2011, 01:13 PM   #36
deadsp0t's Avatar
Only thing is a super chips printed on it and says 2004. The one I had for my other 95 was a little different had a black piece of metal to cover the hole in the ECU with a sticker that said 1995 GT Manual.
---------- Post added at 03:10 PM ---------- Previous post was at 03:08 PM ----------
Originally Posted by Trojan Horse
I believe 195 is stock on most Fox and SN95 Mustangs.
Yes, the 180 would still be less.
Interesting that the switch has 7 positions.
Do you have any information on it as far as brand name and model?
0 is one of the bad settings..
---------- Post added at 03:13 PM ---------- Previous post was at 03:10 PM ----------
Bout start work...
That's unimpressive
Old 10-31-2011, 01:20 PM   #37
Re: 95 GT questions
This is probably what you have.
See the PDF.
Old 10-31-2011, 03:24 PM   #38
93slowstang's Avatar
That's the sct switch. 0 is a no run setting. 1-4 should be the tunes with 4 being the stock settings.
Old 10-31-2011, 04:03 PM   #39
deadsp0t's Avatar
See the PDF.
Can't see the PDF
---------- Post added at 06:03 PM ---------- Previous post was at 06:03 PM ----------
What's 5-7 for?
That's unimpressive
Old 10-31-2011, 09:52 PM   #40
Same thing, but I think you can get programs on those too.
Old 10-31-2011, 09:53 PM   #41
Re: 95 GT questions
Originally Posted by deadsp0t View Post
Can't see the PDF
What's 5-7 for?
You may have to download and install Adobe Reader if you can't see it.
5-7 are not used.
Old 11-01-2011, 01:03 PM   #42
deadsp0t's Avatar
Couldn't find this last time I looked. I believe this is what I have.
After more checking mine out, the FP only primes on 1-4.
http://www.americanmuscle.com/sct-4b...om-9498gt.html
That's unimpressive
Old 11-01-2011, 02:01 PM   #43
Re: 95 GT questions
SCT 4-Bank Eliminator Chip w/ 3 Free Custom Tunes (94-98 GT) - SCT 6600||38023
It matches the PDF file I posted for you.
The tunes listed for it according to switch position on that page may be:
1. Street (87-93 octane) - The street tune is designed as a daily driver program that focuses on increasing mid-range power. Automatic vehicles are further enhanced by making adjustments to the transmission's shift points and firmness.
2. Performance (87-93 octane) - The Performance program is designed to add power at 3000 RPMs and higher, focusing more on the top end horsepower and all out performance driving. Timing, fuel and throttle response settings are slightly more aggressive than the street tune. This is a great track tune but also works well for daily drivers that are looking for a little more "get up and go" than the street tune. The automatic transmission settings are the same as in the street tune.
3. Race (91 - 93 octane) - The race tune will ensure the largest increase in vehicle performance. Using the highest grade of fuel available in your area is mandatory. This file is designed for "Race Use Only", as the timing, fuel, and throttle response settings are very aggressive. It is so aggressive that we do not recommend it for daily driving as it may cause your vehicle to try to jump out from a stop and easily spin the tires. On automatics, we implement entirely new shift points and firmness settings to further enhance the all-out performance of the vehicle.
4. Original Stock Tune
5., 6. & 7. Positions are not used. (Car will not start or run.)
Old 11-01-2011, 04:06 PM   #44
deadsp0t's Avatar
Been running #1.. Going to run #2 tonight.. Add 89-93 gas tomorrow..
That's unimpressive
Old 11-01-2011, 07:32 PM   #45
deadsp0t's Avatar
In position #2 it lunged forward in the drive thru. Good thing I was at the window and not in line too 8D
That's unimpressive
Old 11-01-2011, 08:21 PM   #46
Re: 95 GT questions
Hahaha! Be careful with that new found power.
Old 11-01-2011, 11:34 PM   #47
This chip has a selector switch I assume is for different tunes? On some of the selections after the fuel pump primes it doesn't stop running and the car won't start. On the others is fine.. Any ideas? Intake manifold bolts and other bolts look untouched, I say that because a friend suggested there may have been a power adder before..
Sounds like a nitrous tune
Hawk is offline   Reply With Quote
Old 11-02-2011, 01:17 AM   #48
deadsp0t's Avatar
Right! Hahaha! Am going to put 93 in tomorrow. There is a BP near me that has 100 octane..
That's unimpressive
Old 11-02-2011, 11:24 AM   #49
deadsp0t's Avatar
After some trial and error it seems #1 is the race tune #2 is performance #3 is street and #4 is stock tune. I'm thinking this is a sign that the chip came from a tuner other then AM.
Side note: when I bought the car the dealer said it would give a CEL code if you changed the tune while the car was running. In the AM add it says can be changed on the fly. So last nigh I changed it on the fly(couple times today too) with no issue. Just reassures me it was installed incorrectly before.
---------- Post added at 01:24 PM ---------- Previous post was at 01:23 PM ----------
Wish there was an easy way to tell who tuned the chip..
That's unimpressive
Old 11-02-2011, 11:31 AM   #50
mystang50's Avatar
That 160 T-stat could cause you some issues.
That temp won't let the ECU take the engine out of "cold run" loop and makes it run richer than it should.
A 180 is the lowest temp you should use.
They probably broke the original T-stat housing and had to replace it.
I can't tell you how many times I have seen this over the years.
99.99% of the time it is from over tightening the bolts.
The plugged opening in the top is usually for a temperature sending unit.
However not all vehicles use that port.
If the housing has been changed that could be one sign of a previous power adder installation, but without more evidence to back it up it's really hard to say for sure.
What? I put 160 in mine cuz gets hot prolly cuz u/d pulleys...but still gets hot when its hot outside...could this still cause issue? With cold run loop?
Old 11-02-2011, 11:43 AM   #51
deadsp0t's Avatar
Do you have headers? Mine warms up properly when the temps outside are above
60F, otherwise mine doesn't get to normal. Has it gotten cold where you live yet?
That's unimpressive
Old 11-02-2011, 12:01 PM   #52
mystang50's Avatar
Yeah shortys...it warms up fine but when its hot outside car gets hot...when its cold car runs normal
---------- Post added at 01:01 PM ---------- Previous post was at 12:58 PM ----------
Temp
Old 11-02-2011, 12:05 PM   #53
That's how bama tunes them its the same way with mine.
Old 11-02-2011, 01:36 PM   #54
Also I believe you can give them the serial number on the chip and they should be able to give you the tune info.
Old 11-04-2011, 02:16 PM   #55
deadsp0t's Avatar
Damn I wish I'd had thought of that before lol
That's unimpressive
« sys Q? | A/C Delete »
98 GT gear questions 98RedGT 1996-2004 Mustang GT 14 09-07-2011 03:58 AM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
10:53 PM
