Tuning question? - Mustang Evolution
Old 08-31-2011, 10:05 AM   #1
86gt's Avatar
Tuning question?
If a fox has 30lb injectors and a mass air to match, does it need to be tuned to run properly? If so could that be the reason my car stumbles at WOT then in the higher rpm's runs like a top!
86gt is offline   Reply With Quote
Old 08-31-2011, 10:24 AM   #2
93slowstang's Avatar
You may need to adjust your fuel pressure, providing you have an adjustable regulator.
---------- Post added at 11:24 AM ---------- Previous post was at 11:22 AM ----------
It should run fine without a tune as long as the maf is calibrated for 30# injectors.
Old 08-31-2011, 10:34 AM   #3
86gt's Avatar
Is calibrated for it but like I said, if u romp on it it bogs pretty bad until the rpm's get higher then it starts leveling out??? Can I put on my aeromotive regulator without taking the upper and rails off?
Old 08-31-2011, 10:43 AM   #4
I tried on mine to no avail, you will probably have to. Only took me about 30-45 minutes to change mine and that was with a stripped bolt.
Old 08-31-2011, 11:56 AM   #5
86gt's Avatar
Okay, thanks for your help. I will get her running in a bit and see what pressure I'm running under load and see if it drops any and if it does I'll put in a that regulator!
---------- Post added at 12:56 PM ---------- Previous post was at 12:45 PM ----------
Do you know what pressure I should see at full throttle?
Old 08-31-2011, 11:58 AM   #6
Stock is 40+ at wot.
Old 08-31-2011, 12:22 PM   #7
86gt's Avatar
I appreciate it bud!
Old 08-31-2011, 01:03 PM   #8
No problem man.
Head gasket question ? WhiteCobra94 1979-1995 Mustang GT 17 08-30-2011 09:33 AM
Kenne bell question!! Need help Ahmed ali khan 1996-2004 Mustang GT 26 08-11-2011 04:24 PM
Midpipe Question CodyNelson 1996-2004 Mustang GT 2 08-02-2011 07:45 AM
Question about LT Headers... illestdomer2005 2011-2014 V6 Mustang 4 07-18-2011 12:19 PM
Aft cat deletion question Mustanglife Pre-2005 V6 Mustang 21 06-27-2011 09:30 AM
06:25 AM
