94 aode to t5 neutral safety switch??? - Mustang Evolution
Old 08-31-2011, 01:58 PM   #1
Hey everyone just finished up a conversion from aode on a 94 gt to a t5 from a 95 donor car. I want to return the car to my customer but with all the neutral safety plugs in at the pedels 3 im pretty sure and the harness from the t5 out of the 95 the car will start without having the clutch on the floor (NOT SAFE). I've unplugged all the plugs at the pedals and still it starts............I just read a thousand posts on how the converted cars will not start but this one starts regardless. I'm guessing I have to break the crank circuit and feed the neutral saftey switch at the pedals.....B4 doing this has anyone come across this problem. I appreciate any help!
stangwheeler is offline   Reply With Quote
Old 08-31-2011, 06:30 PM   #2
Under the dash by the pedals is a plug with a jumper wire plugged into it. You will need to remove the jumper and plug it into the clutch pedal safety switch.
Mustangsandiron is offline   Reply With Quote
Old 08-31-2011, 06:49 PM   #3
Jamesgt08's Avatar
I did a swap from auto to manual. I never installed the wire. So im starting my car without clutch pushed in. I kno its not safe but owell. If i sell my car i will fix it.
Jamesgt08 is offline   Reply With Quote
Old 08-31-2011, 07:04 PM   #4
Re: 94 aode to t5 neutral safety switch???
Hey mustangsandiron already did and is presently removed from clutch switch and jumper removed and still cranks over without the clutch pushed in>>>>thx
Old 08-31-2011, 07:06 PM   #5
The auto wire harness will have the jumper at the location where the manual would have the clutch switch. The body harnesses are the same between the auto and man trans.
Old 09-09-2011, 05:30 PM   #6
understood but with the jumper removed and not plugged in car still will crank. no difference if they r plugged in or unplugged??????tested neutral safety switch (clutch pedal switch) and is free and not stuck?????not sure what to do but wire it myself. thanks for your input.
Aode In a Fox? 08v6 1979-1995 Mustang GT 4 08-15-2011 04:05 PM
Major AODE trans 94mustanggt5.0 1979-1995 Mustang GT 18 08-12-2011 09:18 PM
11:55 AM
