Fuel problem help! - Page 2 - Mustang Evolution
Old 09-06-2011, 08:41 PM   #36
Re: Fuel problem help!
Originally Posted by NateNasty View Post
No I did some investigating through the motor too look for blown gaskets. Did all that now it's time too do that iac biz.. Btw I broke my damn thermometer it was on the edge that doesn't effect anything ? Or does it?
What thermometer?
The ECU uses the temperature sensors to help tune the eninge.
Old 09-07-2011, 06:46 AM   #37
NateNasty's Avatar
This
NateNasty is offline   Reply With Quote
Old 09-07-2011, 08:11 AM   #38
93slowstang's Avatar
Looks like your air charge temp sensor. Yes it affects your idle and your car will run rich with it like that.
Old 09-07-2011, 11:59 AM   #39
NateNasty's Avatar
So I went to the auto parts store and they told me that it just goes to a Gage and not to a computer so it should run fine but on the Internet it's 50/50 on it doesn't matter too AHH YOU'LL BLOW YOUR ENGINE! wtf
Old 09-07-2011, 12:08 PM   #40
Originally Posted by Trojan Horse
I was wondering the cost of this, not for me.I have seen kits that cost quite a bit.is it better to scavenge the required parts?
Old 09-07-2011, 03:17 PM   #41
NateNasty's Avatar
Cross your fingers
Old 09-07-2011, 03:42 PM   #42
NateNasty's Avatar
It's the same should I keep letting it run?
Old 09-07-2011, 03:49 PM   #43
86gt's Avatar
If you have a broken water temp sensor then that's what's causing the sporadic idle....I just fixed mine and it slowed my idle back to normal... Now I just have to drive it for around 50 miles or so to fix the rich condition it left me with while it was broke!
86gt is offline   Reply With Quote
Old 09-07-2011, 03:54 PM   #44
NateNasty's Avatar
It's just not idling at all
Old 09-11-2011, 08:15 AM   #45
Probably around $500 to buy everything new.
Cheapest, but more difficult is the junkyard conversion.
Plus with used parts you are never sure of the life left in them or the actual condition until they are installed.
Old 09-11-2011, 08:20 AM   #46
People at your parts store are kind of dumb eh?
Ask them if they will back up their claim with some $$ if they are wrong.
An EFI car uses most all of the sensors in tuning the car to run properly for the operating conditions, and temperature is a definite condition that you need to tune for.
Make your own decision about what you want to believe, but you should have it connected and in good working condition.
Old 09-11-2011, 09:48 AM   #47
GoodfellaBugsy's Avatar
Region: Nevada
Did you adjust the idler screw? Sometimes a slight turn of the screw fixes the problem.
GoodfellaBugsy is offline   Reply With Quote
Old 09-11-2011, 09:27 PM   #48
NateNasty's Avatar
Yeah well I kinda drove it around and it idols now but seem too be idling way too low so when I hit the clutch it'll die unless I work the gas. Where's the idle screw? I thought that was only carbs but I also don't know **** lol
---------- Post added at 10:27 PM ---------- Previous post was at 10:22 PM ----------
It's around + - 500 rpm
Old 09-12-2011, 08:13 AM   #49
86gt's Avatar
Idle screw is right on the throttle cable bracket on throttlebody. If you look under the T.B you'll see where the throttle cable linkage is and there's a screw that holds the linkage in a certain position, kinda like a throttle stop but on the closed end of the throttle body! adjust it in small increments till at the desired idle!
Old 09-12-2011, 08:50 PM   #50
NateNasty's Avatar
I'm gonna do that andddddd a little bird told me to test the thing on the top of the throttle body
Old 09-12-2011, 08:51 PM   #51
NateNasty's Avatar
So I got a new toy to test that to help tune it up. Woo
Old 09-13-2011, 03:37 PM   #52
Attachment 31748
Very useful tool to have.
fuel problem fordgirl1209 Pre-2005 V6 Mustang 10 08-25-2011 06:18 PM
Fuel Filter replacement problem 99 SVT Cobra SVT Mustang 13 07-31-2011 07:25 AM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
Fuel rails Z06 eater 1979-1995 Mustang GT 5 07-17-2011 09:43 PM
Idle problem Stang.racr 1979-1995 Mustang GT 8 07-05-2011 06:19 PM
03:44 PM
