Rear brakes tubing - Mustang Evolution
Old 09-01-2011, 07:28 AM   #1
Rear brakes tubing
Well after getting stuck in florida due the storm and having to drive because we couldn't get a flight I decided to go for a ride in the stang just to get away from the family . Pulled car out of garage put top down went to leave and brake pedal goes to floor and I start to see smoke . I turn cAr off can't find anything start up again step on brAke max hear hiss hiss look under and find a puddle of brake fluid well I blew reAr pass side steel line. Question I cAnt find a junction box under car and the brake line cAnt got from front All the way to the rear cAn it and there is nothing in the mAnuL or online . I don't mind changing the line but I can't see it being 1 piece of 20 ft of bend
tbonestang is offline   Reply With Quote
Old 09-01-2011, 08:54 AM   #2
There should be a junction on the axl housing, the brake line will go from there to the master, there will be two little lines from the junction the the wheel cyl.
Dexter is offline   Reply With Quote
Old 09-01-2011, 09:31 AM   #3
Thanks found it about 10 minutes ago just need to get the tubing now. Now I know I Need to bleed the rear but do I need to bleed the front also
Old 09-01-2011, 07:20 PM   #4
You might want to flush the fluid in the front anyway and maybe look into replacing all the lines. Lack of regular fluid flushes is probably why you had a failure in the rear line. Brake fluid is hydroscopic and makes the lines rust from the inside out when it is not changed regularly.
Mustangsandiron is offline   Reply With Quote
Old 09-01-2011, 08:22 PM   #5
I would agree but car sat for a while
Old 09-01-2011, 10:14 PM   #6
Chances are that if you replace that line the next weekest line will blow out soon, I agree that they all should be replaced with a flush when you can.
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
rear disc brakes swap wss003 1979-1995 Mustang GT 6 07-24-2011 01:46 AM
Rear end in 1994 mustang V6 kevin Grove General Mustang Discussion 4 07-16-2011 06:14 PM
03 v6 rear brake help TaylorF25 General Mustang Discussion 2 07-11-2011 03:58 PM
03 v6 rear brakes TaylorF25 Pre-2005 V6 Mustang 8 06-25-2011 10:01 PM
07:48 PM
