AODE Transmission - Mustang Evolution
Old 09-04-2011, 11:10 PM   #1
FordRacer_51's Avatar
AODE Transmission
I put a used AODE in my 94 gt and it's screwing up. The says the tranny was good. He's telling my computer is what's screwed up. Is there a chance it is my computer is messed up??
FordRacer_51 is offline   Reply With Quote
Old 09-04-2011, 11:16 PM   #2
93slowstang's Avatar
It's always a possibility, what is your trans doing?
Old 09-05-2011, 08:47 AM   #3
Its a it's low on fluid. Like you have to rev it up to get it to move and it acts like it binding up
Old 09-05-2011, 08:51 AM   #4
Did you re-use your torque converter or did you swap it too. Sounds like a worn out torque converter to me.
KnowItAll is offline   Reply With Quote
Old 09-05-2011, 09:19 AM   #5
I swapped it with the one that came with this tranny
Old 09-05-2011, 09:21 AM   #6
Re: AODE Transmission
Sounds like transmission pump/pressure problems to me.
I think "he" just doesn't want to refund your money, but it is possible that your ECU has issues.
Have it scanned and see what shows up.
Old 09-05-2011, 09:26 AM   #7
The check engine lights not even on. Is it possible it is over full??
Old 09-05-2011, 09:28 AM   #8
Overfull would usually make the granny fluid really bubbly. Check for bubbles on the stick. And the transmission controls don't always set a light.
Old 09-05-2011, 09:33 AM   #9
If you overfill an automatic and drive it that way there is a good chance you will blow out some internal seals.
On an automatic too much is as bad as not enough when it comes to fluid.
Old 09-05-2011, 10:01 AM   #10
There's no foam I can scan it with my buddies scanner
Old 09-05-2011, 10:46 PM   #11
What about a neutral safety switch??
Old 09-05-2011, 11:10 PM   #12
I don't understand for sure what you are asking, but the neutral safety switch would keep it from starting if there was a malfunction in the switch.
Old 09-06-2011, 06:21 AM   #13
And sometimes it won't start in park I have to move it to neutral to start
Old 09-06-2011, 07:01 AM   #14
You may need to change out your MLPS (Manual Lever Position Sensor) and make sure your cable(s) are adjusted properly.
Old 09-06-2011, 07:13 AM   #15
Where's that sensor?? I drove it all day yesterday and it work and shifted. It shifted hard but it shifted good
Old 09-06-2011, 07:37 AM   #16
Down on your trans where the shifter cable attaches.
If you don't already own one, you need to get a Chiltons or Haynes manual for your car. It will help when troubleshooting and fixing problems.
Old 09-06-2011, 07:41 AM   #17
Is that the sensor that goes over where the cable hooks up??
Old 09-06-2011, 07:49 AM   #18
No, that's the VSS.
The MLPS fits over the transmission gear selector shaft.
Old 09-06-2011, 03:01 PM   #19
Yea that's the one I was talking about
94 aode to t5 neutral safety switch??? stangwheeler 1979-1995 Mustang GT 5 09-09-2011 05:30 PM
Aode In a Fox? 08v6 1979-1995 Mustang GT 4 08-15-2011 04:05 PM
Transmission problem carlgator 1979-1995 Mustang GT 1 08-14-2011 09:52 PM
Major AODE trans 94mustanggt5.0 1979-1995 Mustang GT 18 08-12-2011 09:18 PM
Transmission issue goherd 2005-2010 V6 Mustang 2 07-22-2011 06:18 PM
09:56 PM
