89 331 - Mustang Evolution
Old 09-05-2011, 03:23 PM   #1
Albaraptor's Avatar
89 331
So I just bought an 89 foxbody with a 331 in it. It has a trickflow intake , trickflow heads , b303 cam , shorty headers, 65 mm throttle body, bbk cai, offroad h pipe, 1 chamber flowmasters 3:55 gears. When u first crank it in the morning it doesn't want to stay running. After it warms up it will
Idle and run fine all day long. Any ideas?
---------- Post added at 05:23 PM ---------- Previous post was at 05:18 PM ----------
1 other thing it set for a month while the guys painted the car and put brand new interior in. I'm sure it's something simple.
Albaraptor is offline   Reply With Quote
Old 09-05-2011, 04:09 PM   #2
Re: 89 331
Try cleaning the MAF and IAC.
Old 09-09-2011, 04:32 PM   #3
94 Mustang GT's Avatar
Did you have this issue before it sat?
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 09-09-2011, 05:21 PM   #4
Albaraptor's Avatar
I just bought it it sat before I got it
---------- Post added at 07:21 PM ---------- Previous post was at 07:06 PM ----------
If I'm missing a header bolt would that cause the problem?
Old 09-09-2011, 05:46 PM   #5
I might have just been cold
16218 is offline   Reply With Quote
Old 09-11-2011, 09:39 AM   #6
Re: 89 331
No, not likely.
Did you clean the MAF & IAC?
Old 09-11-2011, 10:05 AM   #7
Albaraptor's Avatar
Yeah I cleaned both of them
Old 09-11-2011, 01:34 PM   #8
Re: 89 331
Well, if it sat a lot and has not been driven much, you may just need to drive it for a while and let the ECU relearn the operating parameters.
331 vs 347 82stang224 1979-1995 Mustang GT 10 08-01-2011 12:12 PM
07:19 PM
