Front cobra calipers - Mustang Evolution
Old 09-05-2011, 07:50 PM   #1
jwhayne0001's Avatar
After painting my calipers today and looking at then, how exactly does the caliper remove from the bracket? Stupid question, but ive never seen a caliper like it, thanks!
jwhayne0001 is offline   Reply With Quote
Old 09-05-2011, 08:00 PM   #2
Re: Front cobra calipers
You have a few options:
1. Remove brake pads and it will literally fall apart.
2. Remove the locking washer from the pin and slide the pin out, then slide the caliper from the mounting bracket.
Old 09-05-2011, 08:05 PM   #3
Is this pin on the bottom? And is the lock washer like a c clip? And if i just unbolt the bracket and pop the pads out is it easy to pop new ones back in place?
Old 09-05-2011, 08:19 PM   #4
When putting new pads in place I normally just pop the old ones out, use a c-clamp to tighten both pistons back in place, and put the new ones in. Shouldn't need to tighten/loosen/remove anything else.
But yes, the c-clip is what I was referring to.
Old 09-05-2011, 08:23 PM   #5
Alright, thanks for your replies
Old 09-05-2011, 09:00 PM   #6
Cobra Front Caliper Diagram
Name:	Cobra Front Caliper.jpg
Old 09-06-2011, 07:09 AM   #7
removing the brake calipers can be a pain as those bolts are VERY tight and MUST be re installed very tight... (using a TQ wrench is the only way to ensure correct installation and safety fyi but many just tighten the **** out of them....)
Old 09-06-2011, 07:51 AM   #8
The diagram doesn't show bolts, just pins with retainer clips for the Cobra.
Is that correct or did I post the wrong diagram?
Old 09-06-2011, 11:46 AM   #9
It looks exactly like what i have, but i think i only have one pin at the bottom, so what holds the top?
---------- Post added at 12:46 PM ---------- Previous post was at 12:20 PM ----------
Nevermind, theres a little rounded point at the top that goes into a rounded slot and you put that end first then fold it down and insert the pin and c clip, thanks for the help again
Mustang Game 1ijack General Mustang Discussion 8221 08-11-2017 07:22 AM
Cobra Pricing Opinions... 2008Shelby SVT Mustang 25 09-04-2011 03:49 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
Cobra R clearance t0t4lbl4ck0ut 1996-2004 Mustang GT 11 08-17-2011 06:25 PM
01:38 PM
