swapping to 5 lug? - Mustang Evolution
Old 09-06-2011, 01:11 PM   #1
Otlaw80's Avatar
swapping to 5 lug?
I know this question is over asked but I'm at the scrap yard and can pull parts. Is going 5 lug as simple as front spindles ( brakes includes) and rear axles (brakes inc) out of a 95 gt. I know ill have to mess with brake lines and stuff but for major parts will this work.
Old 09-06-2011, 01:26 PM   #2
08v6's Avatar
Front rotors from a Lincoln lsc, and the two left rear axles from a bronco I think go right in no problem
Faster Than A Speeding Ticket! Black 88 Five0, Pull Me Over Red 08v6
08v6 is offline   Reply With Quote
Old 09-06-2011, 01:32 PM   #3
93slowstang's Avatar
Yes they will work. If you get the front spindles get the banjo bolts for the calipers too. That will solve the front brake line problem.
---------- Post added at 02:31 PM ---------- Previous post was at 02:29 PM ----------
Those front rotors will limit wheel choice.
---------- Post added at 02:32 PM ---------- Previous post was at 02:31 PM ----------
Also the rear axle is about .75 in wider on each side.
Old 09-06-2011, 01:33 PM   #4
Otlaw80's Avatar
Thanx for the quick responses. Appreciate it.
Old 09-06-2011, 02:26 PM   #5
bbunt302's Avatar
The rear axles from the 94+ are wider than the 79-93. I would recommend you get the Ranger axles so you have the same length. Can't remember what year model it was though. You can also buy them fairly cheap from Latemodel Restoration Supply. Back when I did mine it was like 200 bucks for the set of axles.
Scary stuff.
Old 09-07-2011, 12:22 AM   #6
Here's a little more detailed idea of what you can do.
http://www.popsracing.com/tech/5lugconversionfox.pdf
i lost the lug nut key!!!!!!! secomejia General Mustang Discussion 23 08-18-2011 08:30 PM
Locking Lug Nut Ket, Where is it? dacriss General Mustang Discussion 3 07-01-2011 08:17 PM
09:01 PM
