New problem - Mustang Evolution
Old 09-08-2011, 01:37 PM   #1
Albaraptor's Avatar
New problem
Now my car will not idle down it tries to then it goes right back up. Would this be tps?
Albaraptor is offline   Reply With Quote
Old 09-08-2011, 03:11 PM   #2
SleepingStang's Avatar
Throwing any codes on check engine? I would assume idle control valve is clogged or faulty. Could remove and clean. But this is all speculation. On a side note the coolant sensor is tied in through the computer to the idle circuit. After about 15-20 seconds the computer reads the temp sensor to trigger the kickdown circuit. Just some thoughts, sorry no immediate remedy.
SleepingStang is offline   Reply With Quote
Old 09-09-2011, 02:43 PM   #3
94 Mustang GT's Avatar
If the engine runs fine while in gear you my friend have a bad iac, but if you also have idle/ cruise problems it's going to ne something else.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 09-11-2011, 10:49 AM   #4
Re: New problem
If you don't already have one get a Chiltons or Haynes manual and follow the procedure for setting the idle and TPS.
Fuel problem help! NateNasty 1979-1995 Mustang GT 51 09-13-2011 03:37 PM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
Drivers side window problem bullitt1075 1996-2004 Mustang GT 3 07-20-2011 10:47 AM
Shift knob problem with steeda tri-ax apex32 2011-2014 Mustang GT 5 06-29-2011 01:04 PM
06:08 PM
