turn signals - Mustang Evolution
Old 09-08-2011, 07:49 PM   #1
turn signals
i dont have any turn signals.if i turn on the hazards all 4 corners flash.when i bought the car it came with a new lever mechanism,so i thought that maybe the previous owner thought that that was the problem so i changed it.i also checked the fuse.any other ideas what could be wrong?
Old 09-08-2011, 08:46 PM   #2
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
a switch
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 09-09-2011, 03:11 AM   #3
Re: turn signals
Its called the "multifunction switch"
Its the turn signal handle you use to turn on turn signals, control wiper speed ect...
Old 09-09-2011, 04:03 AM   #4
Yeah that.lol.I changed it.
Old 09-09-2011, 05:00 AM   #5
Rocco4.6's Avatar
What year is your car?
Rocco4.6 is offline   Reply With Quote
Old 09-09-2011, 10:15 AM   #6
88
Old 09-09-2011, 02:36 PM   #7
94 Mustang GT's Avatar
It's gotta be wiring. If your wipers work and the multi function switch is new and not used.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 09-09-2011, 02:41 PM   #8
00STANG00's Avatar
under the driver side dashboard there switchs a round one try changing that its back up lights but never know what else its used for or look in the trunk for another one some where by the fuel button
SUCK MY DUST
Old 09-09-2011, 05:40 PM   #9
Everything else on the multifunction switch works fine.ill start checking into the wiring
---------- Post added at 06:40 PM ---------- Previous post was at 06:37 PM ----------
Is it possible that that hazard switch is bad since the signals and hazards are linked together.I think I read something about the hazard switch has an override over the turn signals.
Old 09-09-2011, 05:49 PM   #10
It could be a busted bulb I had the same problem and the bulb was just extremely fuc+ed up there was water in it so just check all the bulbs
16218 is offline   Reply With Quote
Old 09-09-2011, 07:07 PM   #11
FordRacer_51's Avatar
I have turn signal issues to some times they work sometimes they don't. But my car has a python alarm on it and I thought maybe it was screwed up??
FordRacer_51 is offline   Reply With Quote
Old 09-11-2011, 09:42 AM   #12
GoodfellaBugsy's Avatar
Region: Nevada
It's the relay switch for the turn signals, 99% positive, that is what the problem was on my 88 mustang. I had same symptoms.
GoodfellaBugsy is offline   Reply With Quote
Old 09-11-2011, 10:00 AM   #13
Re: turn signals
It may be your turn signal flasher.
There are two flashers, 1 for the hazzard lights and 1 for the turn signals.
Old 09-11-2011, 10:50 AM   #14
that makes sense.do the left and right have seperate or do they use the same flasher.i just figured if the hazards work then the signals should.thanx
---------- Post added at 11:50 AM ---------- Previous post was at 11:38 AM ----------
Hey Trojan,I didn't see your thread until it was closed.I just wanted to say good luck on a great recovery!
Old 09-11-2011, 01:08 PM   #15
Re: turn signals
No separate flashers for the left and right sides. The same flasher serves both the left and right turn signals.
Thanks for the well wishes.
Old 09-12-2011, 10:45 AM   #16
Check the bulbs make sure there a all in great condition
Old 09-12-2011, 11:27 AM   #17
A.K.A. Baby-D!
Re: turn signals
check all bulbs. had same problem in my 04 and i had a bad bulb in one of my tailights.
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Left low beam headlight wont work but i will when i turn on high beams p1blake04 1996-2004 Mustang GT 4 09-05-2011 10:30 PM
brake noise only when i turn. mhobbs 1996-2004 Mustang GT 2 08-27-2011 04:07 PM
Sequential turn signals mustangchassy Mustang Paint, Appearance & Detailing 16 08-07-2011 06:35 PM
Car is trembling like it wants to turn off. bobsurvives 1996-2004 Mustang GT 20 07-26-2011 01:46 PM
10:37 PM
