3.73 - Mustang Evolution
Old 09-11-2011, 08:38 PM   #1
3.73
So I did my first rear gear change this weekend.it was not as bad as I thought it would be.does anyone know if there is some kind of break in period?if so are you suppose to be gentle?its hard not to go romp on it.if anyone needs advice let me know.
Old 09-12-2011, 06:22 AM   #2
Re: 3.73
500 miles and then change the fluid using a high quality product, and then always add Fords friction additive.
Our Mustang shop uses Amsoil & Ford additive in the differential. They use different brands for different components all through out the car.
Old 09-12-2011, 06:24 AM   #3
Does that mean to not rip the tires off? Thanx!
Old 09-12-2011, 07:54 AM   #4
Stang.racr's Avatar
I wouldn't yet lol but it is easier said than done
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 09-12-2011, 08:00 AM   #5
Re: 3.73
Good advice!
Try to refrain from "ripping the tires off" until your gears have had time to "break in" a bit and seat together.
P.S. I never could, and I guess I got lucky 'cause it never hurt anything.
Old 09-12-2011, 08:19 AM   #6
It's gonna be hard!lol thanx guys.
Old 09-13-2011, 01:38 AM   #7
Re: 3.73
Did you get Ford gears? Just curious. That's one job I did not do myself. My shop recommended doing what I had to to get Ford kit along with a rebuild kit with bearings ect.
The first 500 miles went by quickly. It was one of the best mods I have done to the car, alot of fun driving after they were put in!
Old 09-13-2011, 08:11 AM   #8
I used the complete kit that came with everything from Ford racing.I got it from LRS
Old 09-14-2011, 01:02 AM   #9
Re: 3.73
Good deal. I got mine from stangmods.com and ended up with an extra set of bearings. So I believe the Ford Racing kit gives you half of the rebuild kit.
Old 09-14-2011, 02:31 PM   #10
It had everything.it came with an extra pinion nut and crush sleeve.it came with 4 bearings and a new seal.
Ok...3.55 vs 3.73 vs 4.10 Gears illestdomer2005 2011-2014 V6 Mustang 16 01-17-2015 09:17 PM
3.73 or 4.10 gears? Which is better? Gobabygo67 General Car Discussion 15 08-30-2011 04:19 PM
need help wot 3.73 Sb98gt General Mustang Discussion 6 07-30-2011 02:55 PM
3.73 gears & MPG. Junkyard 2011-2014 Mustang GT 34 07-21-2011 01:40 AM
07:42 AM
