95 5.0 starting problem - Mustang Evolution
Old 09-12-2011, 02:42 PM   #1
I have replaced the battery and alternator a week ago now the car only starts up when its cool if i drive it then go to start it up it wont all the other stuff like a/c works so shouldnt be the battery
stangrunner is offline   Reply With Quote
Old 09-12-2011, 02:57 PM   #2
I have aftermarket headers and I am having a problem with them getting my starter hot.I haven't fixed it yet,but I'm gonna get some heat wrap.
Old 09-12-2011, 03:23 PM   #3
Im not sure i think im going to replace the starter tomorrow and see what happens i hope thats all it is easy fix
Old 09-12-2011, 03:34 PM   #4
Check your ground try re grounding it
16218 is offline   Reply With Quote
Old 09-12-2011, 03:44 PM   #5
Yeah ill try that thanks
Old 09-12-2011, 04:03 PM   #6
Stang.racr's Avatar
Have auto zone or a shop check yours before u buy a new one
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 09-12-2011, 04:14 PM   #7
89 Foxloco's Avatar
I am more than sure that its the Solenoid Switch..that happen to me long time ago.its about $15. Not expensive.I put two pictures up so you can see how it looks its right next to the battery..
89 Foxloco is offline   Reply With Quote
Old 09-12-2011, 04:28 PM   #8
Thanks ill look into that
Old 09-12-2011, 04:32 PM   #9
Do they have those in 94/95?
Old 09-12-2011, 04:59 PM   #10
Otlaw80's Avatar
Sounds more like a pickup coil inside the distributor to me. But I've also seen full length headers screw up a starter to but it usually just fries them from my experience.
Old 09-12-2011, 07:17 PM   #11
89 Foxloco's Avatar
am not 100% sure..but it has the same engine everything the same except the body.so they should..
Old 09-13-2011, 08:47 AM   #12
jhagan1980's Avatar
If Autozone does test it, it won't show the problem due to not being hot.
jhagan1980 is offline   Reply With Quote
Old 09-13-2011, 10:52 AM   #13
Virgin92's Avatar
It could be your ignition control module in the steering column. To find out use a screw drive and jumper the starter seloniod making contact with two large nuts (make sure key is turned to on position) if it starts your ploblem is not seloniod or started but in steering column
Virgin92 is offline   Reply With Quote
Old 09-13-2011, 11:19 AM   #14
Otlaw80's Avatar
It's not likely its the ignition since it only has problems when hot.
Old 09-13-2011, 01:07 PM   #15
Virgin92's Avatar
I have a 92 lx right now in the driveway that will not start when it's hot I can jump it off with a screw driver and it will start I can also start it on the morning when it's cool out bit as soon as it gets hot it won't even attempt to start
Old 09-13-2011, 01:08 PM   #16
This has happened to me with my 96 gt I started it up let it run turned it off and it wouldn't start you need a good ground
Old 09-13-2011, 01:23 PM   #17
Otlaw80's Avatar
I've seen the ignition module cause the problem (tfi) on the distributor or firewall but not the switch under on the steering column.
Old 09-13-2011, 02:01 PM   #18
Got it fixed it was the starter not to hard to fix little diffrent in this mustang than other cars though
Old 09-13-2011, 02:04 PM   #19
Otlaw80's Avatar
Did u invest in some heat wrap for the header or starter. If it was caused by heat it will help some.
Old 09-13-2011, 02:15 PM   #20
No but im am going to today when i get home
Old 09-13-2011, 02:26 PM   #21
the reason i knew my starter was cranking slow by heat was, where my shorty headers bolted to the h pipe had a leak.i fixxed the leak and now it starts when its hot but cranks slow.the headers are pretty close to the starter.
Old 09-13-2011, 09:20 PM   #22
deadsp0t's Avatar
DRod is likely right, in most cases of slow starting either the ground on the starter or the main ground is bad. The sheathing is bad for splitting open and corroding
That's unimpressive
Old 09-13-2011, 09:31 PM   #23
My leak was leaking right onto the starter.when I fixed the leak it helped tremendously.I agree though that most cases are ground.who knows my ground may be bad also.I was just simply suggesting off a previous experience.
Old 09-13-2011, 09:33 PM   #24
It wasnt the ground i was working on it today the whole starter went bad
Old 09-13-2011, 09:35 PM   #25
At least you found the problem.easy enough fix
Old 09-13-2011, 09:40 PM   #26
deadsp0t's Avatar
Lol my bad! Did read whole thread! Btw sweet hood! Had one on my 1st GT
---------- Post added at 08:40 PM ---------- Previous post was at 08:39 PM ----------
Didn't
That's unimpressive
Old 09-13-2011, 09:44 PM   #27
Thanx
Old 09-13-2011, 09:48 PM   #28
Filibuster
I just replaced this on my car as well...i turned the key to the on possition and jumped the two terminals with a wrentch to start it..
XXSTEVEO66 is offline   Reply With Quote
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 05:49 AM
2011 Mustang 5.0 #8 Cylinder Problem LaFlamaBlanca 2011-2014 Mustang GT 35 08-29-2011 01:38 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 01:52 PM
Boss 302 vs GT 5.0 poloka 2011-2014 Mustang GT 188 06-20-2011 05:08 PM
12:55 AM
