Need help my 5.0 - Mustang Evolution
Old 09-12-2011, 05:43 PM   #1
Need help my 5.0
What's up fellas,
Hey I have been playing with my mustang for a while and have added roller rockers, o yeah, it's a 91 5.0, I have a e-cam, msd 19lb injectors, after adding all that it was running very well it ran great for about three weeks then it started running like it's to rich and then like it's to lean, so I installed a new fuel pump and that isn't help.. So if I'm in to the throttle for a few min then let off the throttle to let it coast or engine brake for a min the hit the throttle again it falls on it's face, now I was just messing around with it running at a idle and pulled the IAC plug and it didn't change a bit??? I haven't yet check the TPS voltage but I wouldn't think that would cause this.. Any ideas????
Thanks for any input
C4king is offline   Reply With Quote
Old 09-13-2011, 04:05 AM   #2
BigRed1781's Avatar
Just a thought, check your fuel pressure & your O2 sensor. O2 could be sending a bad signal causing the ecm to adjust fuel up & down. A A/F ratio gauge would tell you if your rich or lean.
BigRed1781 is offline   Reply With Quote
Old 09-13-2011, 09:10 PM   #3
I put a new pump in it, what should a engine do when you unhook the IAC? Should it run bad? ???
Old 09-14-2011, 12:24 AM   #4
96 stang's Avatar
From what i understand When you unhook the IAC it will idle bad but as soon as you give it gas the MAF takes over. & it should run better while your giving gas.
96 stang is offline   Reply With Quote
Old 09-14-2011, 01:24 AM   #5
BigRed1781's Avatar
Check your fuel pressure regulator.
Old 09-14-2011, 06:36 PM   #6
Re: Need help my 5.0
Have you checked the TPS yet?
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
What is the H O mean in a 5.0 crkmonzo 1979-1995 Mustang GT 16 08-30-2011 08:34 PM
Boss 302 vs GT 5.0 poloka 2011-2014 Mustang GT 188 06-20-2011 04:08 PM
07:35 PM
