dash lights and turn signals - Mustang Evolution
Old 09-13-2011, 05:32 PM   #1
Hey guys, so my recently bought mustang has couple of problems. Right now my dash lights aren't working. I mean I can see the check engine lights and all those when I turn on the car but the lights to show the fuel gauge and the other gauges don't work.
Also my turn signals are not working, I don't know what the previous owner did.
What could the problem be?
88foxstang is offline   Reply With Quote
Old 09-14-2011, 03:46 AM   #2
workmail21's Avatar
Not positive on this but for the blinkers r ur flashers hooked up I had a car that didn't have the flashers hooked up and my blinkers wouldn't work just a guess.
And the dash lights not working again a guess but I had another car that someone ripped the stereo out and it made my lights not work till I put a new one in.
This is all guesses but im sure someone will help u with for sure info
workmail21 is offline   Reply With Quote
Old 09-14-2011, 09:21 AM   #3
deadsp0t's Avatar
My 95 had the same problem, I bought a $20 headlight switch(@the dash)problem solved. My 91 T-Bird, same exact issue.
That's unimpressive
Old 09-14-2011, 06:32 PM   #4
Re: dash lights and turn signals
Did you try twisting the headlight switch knob to make sure someone hasn't just turned them off?
If that isn't the case then you will likely need to replace the headlight switch.
The turn signals may just need the flasher replaced or they could be tied into a headlight switch problem if it is bad.
Old 09-14-2011, 08:48 PM   #5
deadsp0t's Avatar
Actually both my 95's had that issue. In my T-bird the dimmer would actually dim the tail lights out completely
That's unimpressive
Old 09-14-2011, 08:56 PM   #6
Are you out of blinker fluid? Check it. It's underneath the spare tire...
DrSalt22 is offline   Reply With Quote
Old 09-14-2011, 09:09 PM   #7
... Right... Anyway like the other ppl said (not this guy) check for loss wires and ur switch test with aelectrical testing device i cant remember what is called but looks like an ice pick with a see threw screw driver style handle thats got a light in it and a wire comming out the back with a gator clip on it.if the light lights up u got power if not replace part.
Hawk is offline   Reply With Quote
Old 09-14-2011, 09:37 PM   #8
deadsp0t's Avatar
If the headlight switch is bad, when you unplug it from the harness you will see a brownish burnt spot which will be a dead give away no need to spend what could be hours tracking and looking at wires as this is a common problemÓźā
That's unimpressive
Old 09-16-2011, 02:05 PM   #9
Thanks I'm gonna do that this week! I'm gonna let you guys know what happen. I'll be sure to check the "blinker fluid" as that other guy said.... Haha anyways thanks for the posts guys ill keep you updated!
Old 09-16-2011, 07:18 PM   #10
Haha good luck(:
turn signals dreamstang 1979-1995 Mustang GT 16 09-12-2011 11:27 AM
11:36 PM
