Injectors not pulsing? - Mustang Evolution
Old 09-13-2011, 09:53 PM   #1
Otlaw80's Avatar
Been a long few days. After fixing the starter problem (bad starter), then no fuel pump (relay had bad ground), now the injectors are not putting the fuel into the engine. Engine runs if you keep spraying carb cleaner in the intake (yay). So, I put a ground strap from engine to body (was told it mattered) even though I obviously had the negative cable from the engine to battery, and a cable from battery to body. Tried changing out the TFI, and double checked my timing (the distributor was 180 out, oops) Still nothing. I'm thinking possibly the ECM relay or the ECM itself. And to top everything off, my damn water pump is bad also
Any ideas of what to check or thoughts of what could be wrong would be greatly appreciated.
Old 09-14-2011, 03:03 PM   #2
Did you check the fuel filter? Maybe it being clogged caused the pump failure.just a thought.the pump is definitely running?bad regulator?idk
Old 09-14-2011, 03:13 PM   #3
Otlaw80's Avatar
Filter ok. Pump problem was a bad ground wire at the relay. I'm getting fuel to the rail just no pulse by the injectors. I'm pretty sure its an electrical problem just wanted to see if anyone had some other ideas before I start tracing and probing. Thanx for the input though.
Old 09-14-2011, 03:16 PM   #4
im not really the best trouble shooter.just seeing if i could throw something useful at you.i do think your right though if all thats the case it does sound electrical.sorry i couldnt be more helpful
Old 09-14-2011, 03:40 PM   #5
stampde's Avatar
Re: Injectors not pulsing?
ODD the injectors aren't firing ???
and YES You NEED a body to engine block ground , its probably the most important ground of all of them ... I'm thinking ECM
2011 GT Auto
Old 09-14-2011, 05:59 PM   #6
Otlaw80's Avatar
Good to know about the ground. I assumed the negative cable from block to battery, then battery to body would suffice. Thanx for the info. I'm gonna hook up scanner tomorrow to see if it can talk to computer, should give me a good indication of whether the ecm is good or not. (after checking power and ground to it)
Old 09-14-2011, 06:05 PM   #7
Man, When it rains it pours doesn't it.
I feel your pain having been there many times in the past myself.
Check and verify that the ground to your ECU is good.
Remove it and check the surface for rust or corrosion, clean if needed.
A bad ground there can cause a multitude of problems.
Old 09-14-2011, 06:16 PM   #8
Otlaw80's Avatar
Always pouring in my neck of the woods it seems : The ground is the first place i'm checking since i know the problem with my fuel pump was a bad ground. Thanx for info.
Old 09-15-2011, 07:45 PM   #9
Otlaw80's Avatar
Good news, bad news. Good news is I have power to the computer, all the grounds are good at the computer and engine and body. Bad news is, I'm pretty sure the ECM is bad Does anyone know if a ford garage can test the computer when its not in the car?
Also, does anyone have a list of ECM number for auto's / manuals for 86? I've got a VJ1 computer, was told it was a manual, but have found 1 place that said it was an auto?
Old 09-15-2011, 08:02 PM   #10
93slowstang's Avatar
I read it's for an auto, though it doesn't really affect anything. If your ECM is bad now would be a good time to upgrade to mass air.
Old 09-15-2011, 08:04 PM   #11
Otlaw80's Avatar
Was thinking the same thing And i have found 2 more places that state its def for an auto. But I'm a little hesitant because its not a running engine to begin with hmmm...
Old 09-15-2011, 08:33 PM   #12
I don't know how they test them or if they do. If you pull it out and open the case you can check the pathways and capacitors to see if they are burnt up. Thats generally a good indication of a bad ECM.
Old 09-15-2011, 11:15 PM   #13
All I can find for the 86 ECU is:
86 Mustangs had the DA1, VM1, VP1.....
Here's a list that will provide you with options for the MAF conversion if you decide to do that.
ECU/ECM/PCM (Computer) - List for the 88-93 5.0 Mustang
ECU Year Engine MAF Transmission
X3Z 93 5.0 Cobra MAF Manual (Factory Calibrated for 24# Injectors)
Note: If you use the X3Z Cobra Computer, the MAF has to be calbrated for 24# lb injectors for "THAT" computer not any other.
A9L 89-93 5.0 Mustang MAF Manual
A3M 89-93 5.0 Mustang MAF Manual
A3M1 89-93 5.0 Mustang MAF Manual
S0Z 89-93 5.0 Mustang MAF Manual
D3D1 89-93 5.0 Mustang MAF Manual
A9M 89-93 5.0 Mustang MAF Auto
A9P 89-93 5.0 Mustang MAF Auto
C3W 89-93 5.0 Mustang MAF Auto
C3W1 89-93 5.0 Mustang MAF Auto
A9T 89-93 5.0 Mustang MAF Auto
A9S 88-93 5.0 CA Mustang MAF Manual
8LD 88-93 5.0 CA Mustang MAF Manual
8LF 88-93 5.0 CA Mustang MAF Auto
Sorry, the columns would not stay organized properly.
Old 09-16-2011, 01:32 PM   #14
Otlaw80's Avatar
Thanx for the info. I decided to just order a new stock replacement. Don't wanna go changing wires and wonder if there is a problem with them if the car has troubles after its running. So we'll get it right then do the conversion.
Old 09-17-2011, 06:00 AM   #15
When you get ready to do the conversion, here is some info that will help.
File Type: doc Speed Density to Mass Air Conversion .doc (44.5 KB, 524 views)
Old 09-17-2011, 01:07 PM   #16
What year is your stang?
16218 is offline   Reply With Quote
Old 09-17-2011, 01:07 PM   #17
His is an 86.
Old 09-17-2011, 01:10 PM   #18
Originally Posted by 93slowstang
His is an 86.
Sorry can't help to much I had the same problem but I have TBI it was exposed wire contacting the intake manifold
Old 09-17-2011, 03:25 PM   #19
Otlaw80's Avatar
Thanx Trojan. Between this and the 2 write ups I have bookmarked, I shouldn't have a problem.
Old 09-21-2011, 11:12 AM   #20
Otlaw80's Avatar
Ecm came in today. Hopefully I get a chance to put it in tonight and see what happens.
Old 09-21-2011, 12:54 PM   #21
Great! Let us know how it goes.
Old 07-27-2014, 03:12 PM   #22
89 mustang gt fuel problems
I have a 89 mustang gt in the middle of the engine change. the problem i am having is that i replace the fuel pump relay under the seat and the only way the pump will cut on is the by pass the relay. even when bypassing the relay the fuel goes in the lines but nothing works with the injectors. i know i have more than one problem and at the point i am looking for help on what to try or look for so i can finish this project up. not sure where grounds are located at.
lorenparkinson is offline   Reply With Quote
question on cams and injectors CancerBoi69 2005-2010 V6 Mustang 0 09-12-2011 08:09 PM
60 lb injectors question? CZYFAST 2011-2014 Mustang GT 27 07-19-2011 02:56 PM
Fuel injectors 2001 v6 Mustanglife Pre-2005 V6 Mustang 9 07-02-2011 10:36 AM
11:30 AM
