Brakes problem - Mustang Evolution
Old 09-14-2011, 02:33 PM   #1
Brakes problem
Ok all lines bled stops great but every so often it pulls to the left or right when you hit breaks no pattern and not all the time
tbonestang is offline   Reply With Quote
Old 09-14-2011, 02:57 PM   #2
03GT88's Avatar
Could be the condition of the roads causing it. Calipers could be sticking.
03GT88 is offline   Reply With Quote
Old 09-14-2011, 02:57 PM   #3
Ido maybe porportioning valve.
Old 09-14-2011, 03:03 PM   #4
jhagan1980's Avatar
I had a silverado that did this and it was the brake lines collapsing
jhagan1980 is offline   Reply With Quote
Old 09-14-2011, 03:11 PM   #5
speaking of,alot of times the rubber flex lines corrode from the inside out and you cant really tell by looking at them.that could probably cause this also.
Old 09-14-2011, 03:15 PM   #6
It could be the valve or rubber hoses just ran all new steal lines from the master cylinder to front and back
Old 09-14-2011, 03:18 PM   #7
94 Mustang GT's Avatar
No it won't be the proportioning valve, that only deals with front and rear, won't influence either left or right.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 09-14-2011, 03:19 PM   #8
is it possible you bled most of the air out,but maybe still a couple air pockets in there you are catching?
Old 09-14-2011, 03:22 PM   #9
I'm at a loose doesn't look like the calipers are hung and the front end is tight . As for road tried it on the sAme road as before when pulled to the left and strait as an arrow
Old 09-14-2011, 04:03 PM   #10
Filibuster
The rubber flex line is a good place to start if you cant find any other issues!...i had that problem with an 82 camaro I had.it actually locked the front driver side up!...this was any easy fix...to bad I went through new rotors,calipers,and pads before I was told about the lines!!...
XXSTEVEO66 is offline   Reply With Quote
Old 09-14-2011, 04:04 PM   #11
Checked and bleed them again bit no difference
Old 09-14-2011, 06:13 PM   #12
Re: Brakes problem
Sometimes the rubber brake hoses can suffer a blowout internally on the inside liner and a flap of rubber will drop down preventing the fluid from returning properly. This could cause the problem you described.
At any rate replacing the rubber lines is always a good idea if you are not sure of their condition.
Maybe consider replacing them with braided lines which are much stronger and give a much better pedal feel.
Old 09-14-2011, 07:01 PM   #13
03GT88's Avatar
I think he said he ran new steel lines.
---------- Post added at 08:01 PM ---------- Previous post was at 08:01 PM ----------
Do you have new pads? If so did you seat them?
Old 09-14-2011, 07:04 PM   #14
you still have to have a flex line since the wheels move and turn
Old 09-14-2011, 07:15 PM   #15
I had to replace all the steel lines busted a whole the rear and after looking and pushing a screw driver through in the front with out any effort it was time to replace . As for pad all new and next will be the flex ones but guess what I take it for a ride to test and mow its bogging when you give it gas and idle is horrible just fixed all thAt fels likes it gonna stale and them it takes off gonna change the fuel fitter I am starting to really not like this car
Old 09-14-2011, 09:10 PM   #16
03GT88's Avatar
True. Thought he probably upgraded that too with braided.
---------- Post added at 10:10 PM ---------- Previous post was at 10:08 PM ----------
Did you break the brakes in after the new pads? Heavy accel and heavy braking sessions?
Old 09-15-2011, 02:30 PM   #17
Just gonna change all the hoses and calilers I thinking maybe moisture might have got in their yeah more money
Old 09-15-2011, 02:58 PM   #18
FordRacer_51's Avatar
I have had these issues before I changed the brakes hoses worked like charm!!
FordRacer_51 is offline   Reply With Quote
Old 09-15-2011, 03:17 PM   #19
I would just so that but I hate doing the same sh&t almost twice and it's only just two more bolts but one less hose connection unhook and trash
Old 09-16-2011, 11:00 PM   #20
deadsp0t's Avatar
Something could be lodged in the caliper between the piston and caliper. This will also cause the pads to wear at different rates. Maybe when you changed the pads you noticed one pad had more pad material left or one side was worn noticeably more the other. Example if the times it pulls it pulls right, maybe something is hindering the pistons in the left caliper. I've had an issue very similar to this and turned out small gravel was wedged in there. You don't have to be driving down dirt roads for this to happen.
Also braided brake lines are great, they give you good pressure and also help it be consistent. They will also give you you better feed back through the pedal to what the brakes are doing. Good luck
That's unimpressive
Need Help Engine Problem! PonyBoyV6 Pre-2005 V6 Mustang 6 08-30-2011 05:16 PM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
conversion disc brakes? 1faststang Classic Mustangs 15 08-11-2011 01:30 AM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
Cooling fan and AC problem, please help 95GTS 1979-1995 Mustang GT 4 07-08-2011 08:24 PM
08:19 AM
