Tires question!! - Mustang Evolution
Old 09-14-2011, 06:36 PM   #1
89 Foxloco's Avatar
Tires question!!
I have a 89 fox body.I just ordered some 17 inch rims.what is the size of the fattest tire I can put in the back without hitting the shock or having to put spacers.. thanks..
89 Foxloco is offline   Reply With Quote
Old 09-14-2011, 06:37 PM   #2
Re: Tires question!!
Probably a 275 series tire.
Old 09-14-2011, 06:41 PM   #3
93slowstang's Avatar
+1, also how wide is the rim? If it's 9" wide a 275 is the widest recommended for it. Any wider and you have to remove the quad shocks.
Old 09-14-2011, 07:48 PM   #4
89 Foxloco's Avatar
Its 17x9.. The rim..
Old 09-14-2011, 08:08 PM   #5
275 is the max on those.
Old 09-14-2011, 08:08 PM   #6
Another vote for 275 here.
Old 09-14-2011, 08:10 PM   #7
I'm running 275/40 on mine with no issues.
---------- Post added at 09:10 PM ---------- Previous post was at 09:09 PM ----------
With a 2 1/4" drop overall as well.
Old 09-14-2011, 09:20 PM   #8
U cant run wider then 275 on a 9 in rim (i should now i work in a tire shop) it puts to much stress on the bead to go wider and generates a serious blow out risk however i have seen as wide as 305 on the back of a 88 gt with no wheel tubbing done but i dont know if spacers were used nor do i know what the rim offset was i do know that 10in rims were used. (18x10)
Hawk is offline   Reply With Quote
Old 09-14-2011, 10:18 PM   #9
A 79-93 Fox Body running a 10" rim with a 295x50x15 tire requires a 6.5" backspace. That rim and tire size will require that you roll the lip on the outer fender and massage the inner fender with a hammer to get adequate clearance.
A 275 tire will fit rims sized from 7.5" to 9.5" and it has a section width of 10.82"
Old 09-15-2011, 12:35 AM   #10
89 Foxloco's Avatar
Thanks to everyone!!!
Old 09-15-2011, 01:12 AM   #11
deadsp0t's Avatar
I put 275's on six bar's one time. Looked sick and hooked soooo well. Swayed real bad in corners though. I guess with that much bulging over the lip of the rim there was a lot of deflection in the side wall. But damn they looked sick
That's unimpressive
Old 09-15-2011, 07:12 AM   #12
you didnt even mention the most important part of the rims, backspacing/offset?
Old 09-15-2011, 10:00 AM   #13
deadsp0t's Avatar
That's unimpressive
2012 5.0 Brembo Wheels and Tires Up For Sale avengnd Mustang Parts for Sale and Wanted 5 09-11-2011 01:45 PM
Question yazeed gt General Car Discussion 12 09-06-2011 06:48 PM
2011 mustang 19" wheels with tires gtstyles2 Mustang Parts for Sale and Wanted 3 09-03-2011 11:56 AM
Kenne bell question!! Need help Ahmed ali khan 1996-2004 Mustang GT 26 08-11-2011 04:24 PM
Tires Mach1fan General Car Discussion 7 08-09-2011 12:19 PM
11:32 PM
