Bad Fuel Pump?? - Mustang Evolution
Old 09-15-2011, 03:21 PM   #1
Bad Fuel Pump??
Got the tranny fixed, now my baby is hard to start. Once started, runs great. If I "hear" the fuel pump the car starts right away, if I don't hear anything it takes about two turns of the key to get it going. does this mean I should be looking for a new fuel pump?
jal4411 is offline   Reply With Quote
Old 09-15-2011, 03:39 PM   #2
93slowstang's Avatar
It may also be your relay. Is it giving you any drivability problems at all?
---------- Post added at 04:39 PM ---------- Previous post was at 04:38 PM ----------
Sounds like the relay though.
Old 09-15-2011, 03:41 PM   #3
Re: Bad Fuel Pump??
No driveabillity issues at all.
Old 09-15-2011, 03:46 PM   #4
I would check the relay first then, usually you will have drivability problems when it starts going bad.
Old 09-15-2011, 11:23 PM   #5
Re: Bad Fuel Pump??
You may also be experiencing an intermittant ignition switch problem.
Old 09-17-2011, 08:47 AM   #6
deadsp0t's Avatar
+1
especially if your ignition switch is loose like mine and after you remove the key the car still chimes with the door open, and can be stopped by moving the switch with the key out.
Trojan is this as easy as replacing the the key cylinder to fix or does the ignition switch on the column have to be replaced also? In his issue and mine?
That's unimpressive
Old 09-17-2011, 09:59 AM   #7
Re: Bad Fuel Pump??
Originally Posted by deadsp0t View Post
+1
Replacing the key cylinder will cure any sloppiness there, but you will still need to install the ignition switch to cure any electrical issues.
Old 09-17-2011, 02:32 PM   #8
Re: Bad Fuel Pump??
well today the ac wouldn't go on..........will have the ccrm replaced next week. mechanic says its about a $90 part and not too much labor so it doesn't seem that bad but I wonder what's next.
Timing or fuel BigRed1781 1979-1995 Mustang GT 2 09-12-2011 08:53 PM
Think water pump is gone? Whiterocknotch 1979-1995 Mustang GT 11 09-04-2011 08:39 AM
Fuel pump constantly running Albaraptor 1979-1995 Mustang GT 3 08-28-2011 02:55 PM
fuel problem fordgirl1209 Pre-2005 V6 Mustang 10 08-25-2011 06:18 PM
Fuel Filter replacement problem 99 SVT Cobra SVT Mustang 13 07-31-2011 07:25 AM
05:42 PM
