Turbo - Mustang Evolution
Old 09-18-2011, 07:20 AM   #1
Turbo
I want to stick a turbo in my 95 gt has the 5.0 shift kit cold air intake new gears. Need as much info as i can get on cost for a cheap one and what i need to do to get my stang ready for one thanks
---------- Post added at 09:20 AM ---------- Previous post was at 09:19 AM ----------
I found a godspeed turbo for 300 on ebay good deal?
stangrunner is offline   Reply With Quote
Old 09-18-2011, 09:47 AM   #2
Re: Turbo
Never heard of a "godspeed" turbo, but the name alone would make me shy away from it.
See your post on superchargers for info on what you will need to get your car ready as engine requirements are close to the same.
A turbo will be much more complicated and expensive than a supercharger as you will have lots more components such as manifolds, tubing, blow off valves, intercoolers, etc. etc. thna you do with a SC.
See the sticky post on SC & TC, follow the links and you will find components and turbos. I believe they said a TC Kit could be put together for around $2k.
Old 09-18-2011, 09:52 AM   #3
Re: Turbo
Just buying a turbo is the least of your purchases...
You will need all of the piping from your manifolds to the turbo, piping from the turbo to the intercooler, an intercooler, piping from the intercooler to the intake, wastegate(s), blow off valve, wastegate springs, etc etc etc....
You also will need to figure out what size turbo you want to go with, or if you want to go with two. Are you wanting a quick spool without a ton of top end, do you want alot of lag down low but a ton of power in the top of the power band?
Also, how are you going to tune the car for the turbo, will probably be easier to convert to a blow-thru setup on a 95, but you will need bigger injectors at a minimum.
O, and throw your cold air intake away, it's useless when going turbo.
Old 09-18-2011, 02:48 PM   #4
Cheaper turbos I believe usually still work good,but may not last as long.cheaper bearings,etc.
Old 09-18-2011, 06:34 PM   #5
Lapida's Avatar
Re: Turbo
Cheaper Tyrbo kit for the 95 GT
1994 1995 5.0 **MUSTANG GT TURBO KIT** 94 95 sn95 | eBay
Lapida is offline   Reply With Quote
Old 09-18-2011, 06:59 PM   #6
93slowstang's Avatar
Originally Posted by Lapida
The pipes and intercooler would probably be fine, I wouldn't use that turbo though.
Old 09-19-2011, 08:00 AM   #7
mystang50's Avatar
http://www.on3performance.com/mustangsn5.html
Ima prolly buy one for my 95 should come with everything injtrs,piping,fuel pump,and everything in-between.pretty gods price imo...good luck
Old 09-19-2011, 08:06 AM   #8
Re: Turbo
most good quality turbo kits will be 5-7k then you have to pay for install and then for tuning and all the other little things needed that may not come with the kit (injectors, fuel pump etc)
Old 09-19-2011, 08:59 AM   #9
mystang50's Avatar
This on3performance 1 you can order a side package that comes with pump injtrs and maf and all that
Old 09-19-2011, 09:20 AM   #10
drusmith's Avatar
Send a message via Yahoo to drusmith
Re: Turbo
I will repeat what Lowfyln and SpectorV said: the most important things to think about are Fuel upgrade (bigger injectors, Fuel pump) and good tune!
Plan on double what ever you spend on a Turbo kit you will spend on fuel upgrades and professional tune.
---------- Post added at 11:20 AM ---------- Previous post was at 11:12 AM ----------
This is what I would recommend. It has everything included! Just1979-1995 mustang turbo system need to install and Tune!
drusmith is offline   Reply With Quote
turbo mystang50 1979-1995 Mustang GT 10 08-23-2011 11:06 PM
Turbo!!! Z06 eater 1979-1995 Mustang GT 3 07-31-2011 02:53 PM
Turbo DrSalt22 2005-2010 V6 Mustang 7 07-17-2011 12:21 PM
Turbo and tranny Z06 eater 1979-1995 Mustang GT 5 07-12-2011 09:10 PM
Turbo question! 93stang306 1979-1995 Mustang GT 14 07-10-2011 02:44 PM
04:44 AM
