Firing order? - Mustang Evolution
Old 09-18-2011, 02:57 PM   #1
86gt's Avatar
Firing order?
I'm sure it's been on here before but I can't find it so can anyone tell me what are the standard firing orders for 302's and 351's...and what are the determining factors in why some year models are different?
86gt is offline   Reply With Quote
Old 09-18-2011, 03:31 PM   #2
93slowstang's Avatar
Here ya go for the firing order
---------- Post added at 04:31 PM ---------- Previous post was at 04:31 PM ----------
http://www.302w.com/Firing-Order.aspx
Old 09-18-2011, 03:45 PM   #3
86gt's Avatar
On the cap is that counterclockwise or no?
Old 09-18-2011, 03:56 PM   #4
WhiteCobra94's Avatar
Firing order is 1 3 7 2 6 5 4 8
Old 09-18-2011, 04:05 PM   #5
Yes counterclockwise
Old 09-18-2011, 04:07 PM   #6
86gt's Avatar
For some reason clockwise from the nipple on top of the cap I've got
7 3 1 8 4 5 6 2.....why in the hell would someone that's owned a mustang for at least 10 years and completely rebuilt several of them put the wires in that order?!?
Old 09-18-2011, 04:12 PM   #7
That's the firing order backwards, should be right on the cap.
Old 09-18-2011, 04:13 PM   #8
86gt's Avatar
Ok so does the nipple on the cap mean anything? Shouldn't the number one go right after that nipple or no?
Old 09-18-2011, 04:15 PM   #9
What kind of cap is it, it would be easier to say yes or no with a visual aid.
Old 09-18-2011, 04:19 PM   #10
86gt's Avatar
That is the wire for that # 1 cylinder and counterclockwise from there it is 17326548...
Old 09-18-2011, 04:23 PM   #11
86gt's Avatar
Shouldn't in all be rotated 4 positions?
Old 09-18-2011, 04:25 PM   #12
Yes
---------- Post added at 05:25 PM ---------- Previous post was at 05:24 PM ----------
Sorry 13726548*
Old 09-18-2011, 04:25 PM   #13
86gt's Avatar
Thanks for the help...I'll go give it a try and see how she runs!!!
Old 09-18-2011, 04:27 PM   #14
Huh? You mean how the wire are positioned.
Old 09-18-2011, 04:46 PM   #15
86gt's Avatar
Ok.. In the pic you can see the # 1 on the cap but the wire with my finger on it is the #1 wire.....I tried rotating all the wires one post over so the number 1 wire was in the 1 position on the cap and it wouldn't start, So what's up with that?
Old 09-18-2011, 05:04 PM   #16
Someone probably re-stabbed the distributor off a little. #1 changed on mine after my hci when I re-stabbed mine. If it really bothers you you can take the distributor out and roll it to make it match.
Old 09-18-2011, 05:14 PM   #17
86gt's Avatar
It's not that it bothers me, it's just that I'm trying to figure out what's going on with my rich condition and it just running like sh** in general! Hoping that it could be the wiring and have never seen it off like that!
---------- Post added at 06:14 PM ---------- Previous post was at 06:08 PM ----------
Thanks for your help slowstang!
Old 09-18-2011, 05:20 PM   #18
It's no problem at all, trying to rundown in my head how I solved my problem running too rich.
Have changed the plugs recently? An injector may be sticking as well.
Old 09-18-2011, 05:42 PM   #19
86gt's Avatar
Yeah I'm thinking it's an injector also...I think i have a blown head gasket too so I guess I'll start tearing it down, just not looking forward to it. What other than timing would make it stumble bad when under acceleration....first gear is alright but in second and up if you just give it a little gas it's fine but any more than 1/4 throttle and it bogs so bad it almost dies
Old 09-18-2011, 05:49 PM   #20
A bad tps, running too rich or lean, a plug wire grounding out. Probably a couple more things I'm forgetting.
Old 09-18-2011, 08:09 PM   #21
Re: Firing order?
The determining factor is in how trhe camshaft is ground.
The 302/5.0 HO uses a camshaft ground with the 351W firing order.
This produces a bit more power and less stress on the engine block.
Standard 302/5.0 engines use a camshaft ground with the same firing order as the FE & 429-460 engines.
Here is a diagram that will help you visualize it better.
Name:	5.0-5.8 Firing Orders.jpg
Old 09-18-2011, 09:36 PM   #22
This is from edelbrock
New shoes on order!!! poloka 2011-2014 Mustang GT 37 09-19-2011 07:41 PM
Custom Tunes vs Mail Order Tunes illestdomer2005 Pre-2005 V6 Mustang 13 08-14-2011 07:23 AM
Any order? nickcap 1979-1995 Mustang GT 8 08-01-2011 10:13 PM
What does it cost to supercharge a 2012 gt at a ford dealer? I have a GT on order. brickcart 2011-2014 Mustang GT 36 07-02-2011 09:16 AM
03:36 PM
