1993 Cobra Exhaust Question - Mustang Evolution
Old 09-19-2011, 11:14 AM   #1
Just bought my first Mustang, it's a 93 Cobra. The previous owner has a set of catless Flowmaster H pipes. They are a bit louder then I am looking for. I am looking for some thing that will give me a nice deep growl when idling and in a lower gear but will be quieter while in a higher gear at highway speeds. I was looking at a set of Magna flows but I'm looking for suggestions. Right now its almost impossible to talk while inside the car to a passenger while driving because of how loud it is.
Baron164 is offline   Reply With Quote
Old 09-19-2011, 11:19 AM   #2
drusmith's Avatar
Send a message via Yahoo to drusmith
Re: 1993 Cobra Exhaust Question
Add high-flow cats to it! that will help a ton!
drusmith is offline   Reply With Quote
Old 09-19-2011, 11:23 AM   #3
Titus Wadicus
svtlx's Avatar
not having cats is going to be loud regardless of muffler choice unless u use stock mufflers. now that im thinkn bout it, that may be the sound you are looking for since you dont have cats.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 09-19-2011, 11:25 AM   #4
drusmith's Avatar
That works too!
Old 09-19-2011, 11:48 AM   #5
Well I'm probably going to get something with cats to make it quieter but I have to get new pipes so I figure I'll just replace everything minus the headers.
Old 09-19-2011, 11:49 AM   #6
How much did u pay for it?
16218 is offline   Reply With Quote
Old 09-19-2011, 11:51 AM   #7
For the car?
Old 09-19-2011, 11:51 AM   #8
Yea? If I'm not mistaken it's rare?
Old 09-19-2011, 11:56 AM   #9
$7000, it was in a minor accident and had the door replaced so it's not a numbers car anymore. But the body was still in good shape and I'm going to restore it to factory quality minus a few minor upgrades.
Old 09-19-2011, 12:03 PM   #10
7? Still isn't to bad
Old 09-19-2011, 12:08 PM   #11
Yeah, I'm very happy with it. The floor pans are still all straight. It was painted but it doesn't match so after paint and a few other minor things it should be near perfect. Just need to replace the exhaust with something a little more subtle and since New York is getting more strict about emissions adding cats back in is probably going to be mandatory.
Old 09-19-2011, 04:05 PM   #12
Now is the passenger ur gf or wife it makes all the difference if it's ur gf quiet the car down if it's your wife make it louder leas u have to hear her
tbonestang is offline   Reply With Quote
Old 09-19-2011, 04:08 PM   #13
+1000000000
Old 09-19-2011, 04:08 PM   #14
Las0mbra's Avatar
+99999999999999999
1993 cobra, exhaust
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
exhaust question... (04 GT) Topless04GT 1996-2004 Mustang GT 7 07-23-2011 04:10 PM
1998 v6 exhaust question?? Gt.Vert Pre-2005 V6 Mustang 6 07-23-2011 12:29 AM
Exhaust question Blackedout Pre-2005 V6 Mustang 4 06-29-2011 08:07 AM
04:18 PM
