Explorer Intake? - Mustang Evolution
Old 09-19-2011, 11:23 AM   #1
crkmonzo's Avatar
Explorer Intake?
This kid at school said putting the explorer intake on the 5.0 would give it more horse. is this true and would it even fit?
crkmonzo is offline   Reply With Quote
Old 09-19-2011, 11:27 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Explorer Intake?
it will fit, but dont expect big gains just by bolt'n it on. u need a lil bit more than that.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 09-19-2011, 11:28 AM   #3
5.slow's Avatar
Region: Delaware
A little. Put the explorer heads and an e303 cam on with it to see a bigger upgrade.
5.slow is offline   Reply With Quote
Old 09-19-2011, 11:31 AM   #4
93slowstang's Avatar
+1, it's a noticeable difference.
Old 09-19-2011, 11:32 AM   #5
crkmonzo's Avatar
what year ?
Old 09-19-2011, 11:33 AM   #6
5.slow's Avatar
Region: Delaware
Any year with a 5.0 motor, mostly mid to late 90's
Old 09-19-2011, 11:35 AM   #7
crkmonzo's Avatar
alright thanks
Old 09-19-2011, 11:41 AM   #8
Yes, the Explorer manifold flows just slightly less than the Cobra and it costs a lot less too.
Like the guys said the intake alone won't make much difference, but when you pair it up with the GT40 or better heads, e303 cam, bigger TB and MAF, you will see an appreciable gain.
Intake Suggestions..... Srohda 2011-2014 Mustang GT 42 09-19-2011 03:56 PM
Pictures of Intake!!! nickcap 1979-1995 Mustang GT 22 08-04-2011 05:02 PM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
5.0 Intake cover RED! wnt2gofst Mustang Parts for Sale and Wanted 2 07-04-2011 11:11 PM
07:28 PM
