Fuel gauge!! - Mustang Evolution
Old 09-20-2011, 12:11 AM   #1
89 Foxloco's Avatar
Fuel gauge!!
I need help installing a fuel gauge.my whole cluster us messed up.its a 89fox.its going to be a performance gauge since the original messed up..thanks..
89 Foxloco is offline   Reply With Quote
Old 09-20-2011, 01:38 AM   #2
Re: Fuel gauge!!
Make sure you get a gauge with the correct ohm range for your application or it will not read correctly.
Old 09-20-2011, 07:32 AM   #3
89 Foxloco's Avatar
And how do I know that ohm of my car?? Is the installation easy??
Old 09-20-2011, 08:50 AM   #4
Re: Fuel gauge!!
The gauge manufacturer should list the sending unit ohm range you will need, but if they don't:
75-10 Ohms (Ford Type Sending Units '86 and earlier)
16-158 Ohms (Ford Type Sending Units '87 and later)
The installation is of medium difficulty I would say.
Old 09-20-2011, 09:46 AM   #5
89 Foxloco's Avatar
Oh ok..thank you very much..
Old 09-20-2011, 09:51 AM   #6
Re: Fuel gauge!!
You are welcome, good luck with your install.
Old 09-22-2011, 10:00 AM   #7
89 Foxloco's Avatar
It was ready installing it but they told me I have to change the fuel flotater something like that.
Old 09-22-2011, 11:55 AM   #8
Re: Fuel gauge!!
Probably the sending unit and float?
Old 09-22-2011, 12:05 PM   #9
89 Foxloco's Avatar
Yeah that!!
Old 09-22-2011, 07:20 PM   #10
Jettin Stang's Avatar
How hard is it to do that? N what all do u have to do
Jettin Stang is offline   Reply With Quote
Old 09-22-2011, 08:12 PM   #11
Filibuster
Depends on how full your gas tank is!!....the sending unit and float are inside the gas tank.
You'll need to drop the tank to replace them.hence the less gass in the tank the lighter and easier it will be!!..
---------- Post added at 09:12 PM ---------- Previous post was at 09:07 PM ----------
My gass gauge is jacked up as well..20$ in premium puts my gauge at full!?..when it drops it drops FAST!!
From full to empty in about 20mi or so!...id guess my float is whacked..
XXSTEVEO66 is offline   Reply With Quote
Old 09-22-2011, 10:27 PM   #12
Re: Fuel gauge!!
Sounds like your sending unit is sticking or the resistor coil is damaged in some way.
Fuel gauge not working after CAI install. Hellraisen 1996-2004 Mustang GT 0 09-14-2011 06:58 AM
Fuel gauge BigB227 1996-2004 Mustang GT 2 08-27-2011 06:26 AM
fuel pressure gauge XXSTEVEO66 1979-1995 Mustang GT 9 08-12-2011 03:02 PM
Is this fuel gauge worth getting? scorpiouno 2005-2010 V6 Mustang 2 07-17-2011 02:28 AM
Fuel gauge issue macmarine39 1979-1995 Mustang GT 7 07-16-2011 05:19 PM
11:30 PM
