Sterring shaft hitting header - Mustang Evolution
Old 09-20-2011, 08:12 PM   #1
Chris01's Avatar
Got my engine finally ready to be put back in the car and now my steering shaft is hitting the header.. It's a flaming river shaft and bbk headers. I was thinking about making the whole bigger where the bolt goes tru at the top of the shaft so it can slide out more and put more of a angle on it so it won't hit it.. Anyone else have seen this problem?
ID:	32003   Click image for larger version
Chris01 is offline   Reply With Quote
Old 09-20-2011, 08:36 PM   #2
Re: Sterring shaft hitting header
Yes, We always used a ball pein hammer and carefully dimpled the header for clearance.
I'd be really careful modifying the steering shaft.
Old 09-20-2011, 10:20 PM   #3
Titus Wadicus
svtlx's Avatar
+1... beat it till it clears!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 09-21-2011, 08:45 AM   #4
I had the same problem but i used the stock steering shaft. loosen the steering column and put a wedge of wood between where the header and steering shaft meet then tighten the steering column and remove the wooden wedge. you should have the space u need to clear the header. I know this works with the stock shaft, fox body, Hopefully it will work for you. good luck
393notch is offline   Reply With Quote
Old 09-21-2011, 10:14 AM   #5
Chris01's Avatar
I might try the block of wood trick to see if I get any room..
Old 09-21-2011, 02:01 PM   #6
Youve got nothing to Lose. Took me literally 5 minutes. Good luck
Old 09-21-2011, 10:01 PM   #7
Chris01's Avatar
Thanks
04:40 AM
