What it takes for forced induction and much more... - Page 38 - Mustang Evolution
Old 07-20-2012, 01:53 PM   #1296
Re: what it takes...
What determines the weight you need your HB to be? I see this one is 50oz.
The balance on your crankshaft.
The 50 oz imbalance is a stock 5.0 balance weight from 198? and up.
Your flywheel has to be made for that imbalance too.
Old 07-20-2012, 02:56 PM   #1297
Lorraine's driver
ab_mach1's Avatar
So it's down to the design of the engine? Like a fox 5.0 needs a 50oz HB and the 4.6L would need "x"oz HB?
Instagram: @ab_mach1
Old 07-20-2012, 03:02 PM   #1298
Yeah, It just depends on how they were balanced from the factory or if that has been altered during a rebuild.
Old 07-20-2012, 03:07 PM   #1299
Lorraine's driver
ab_mach1's Avatar
Ok, I get it now. So this info needs to be passed on to the dude assembling the engine? Sounds boobish, but I've wondered why they called it a harmonic balancer :duh:
Old 07-20-2012, 03:20 PM   #1300
Well, the guy assembling the engine should know all of this to be truthful.
It is called that because that is what it does. It dampens the harmonic vibrations of the crankshaft.
Old 07-20-2012, 03:48 PM   #1301
Lorraine's driver
ab_mach1's Avatar
Thanks TH!
Old 07-21-2012, 11:42 AM   #1302
Filibuster
Goin to my local race shop later for stuff on the 454 camaro swap...anywho im gunna try and find the v traction stuff for my d/r's and some decent hood pins..
Hood pins because yesterday on a lonely road my car needed to breath a bit and I noticed that at 100+ my hood likes to dance a bit. Ive never noticed this before yesterday,but it really made think of how much it would suck to lose a hood at 100+ :/
XXSTEVEO66 is offline   Reply With Quote
Old 07-21-2012, 11:49 AM   #1303
Lorraine's driver
ab_mach1's Avatar
Definately! Especially if it made you eat a ditch or taste a tree while freaking out from the flying hood.
Old 07-21-2012, 12:25 PM   #1304
IMO you should always use hood pins with fiberglass hoods.
I've seen several Mustangs with crushed cowl vent areas because the glass hood flew up and the cowl is a huge PITA to replace.
Old 07-21-2012, 01:06 PM   #1305
Filibuster
Got a few more goodies for the BB and got my hood pins not to bad fer $10..
ID:	60179   Click image for larger version
Old 07-21-2012, 01:28 PM   #1306
You know, if you'd sell all that BBC stuff you could get more goodies for the Mustang.
My Cervinis hood was doing the same thing as you described, even with the latch properly adjusted. That made me nervous, so I put some pins on mine soon after.
They have some really nice twist lock pins on the market these days, but they seem to think they are worth their weight in gold.
Old 07-21-2012, 01:48 PM   #1307
Filibuster
Luckily im not paying for any of these BB goodies...it's my enigine that we're puttin in my buddies maro so he's got the mod bug at the moment lol...I wish I could drop this much on my stang right now!..
Yeah they had the hood pins I bought and also ones without the lanyard and the ones with the flip rings..but these ones just scream old school so I went with them..
They come with self tapping screws for the bottom plate but im thinking of rivets instead. any opinion on that?
Old 07-21-2012, 02:15 PM   #1308
Hood pins are on my list also. I've never seen my hood budge, but it does make me nervous how light my hood is.
---------- Post added at 03:15 PM ---------- Previous post was at 03:14 PM ----------
I think rivets would leave a nice clean look. I say rivet that sum o bit**
Old 07-21-2012, 03:38 PM   #1309
Rivets will work, but you must have the backup washers or they will splinter the fiberglass.
Also use either SS or aluminum rivets as the plain steel will rust quickly.
Old 07-21-2012, 03:39 PM   #1310
Are you trying to say "sunny beach" ?
Old 07-21-2012, 04:42 PM   #1311
No. Hillbilly for son of a bitc*. Lol
Old 07-21-2012, 04:44 PM   #1312
Filibuster
Damn...the oil pan is a no go with the oil pump. The original pan was deeper so the pump had a brass block spacer we figured eliminating that and getting the stock shorter lenght pump shaft would be good,but apparently the pump pickup still sits to low..
Old 07-21-2012, 05:34 PM   #1313
That's what "Sunny Beach" is too, or maybe it's the redneck version?
You know, like the dirty, rotten sunny beach!
Old 07-21-2012, 05:37 PM   #1314
That sux. Can you modify the pickup to the proper height?
---------- Post added at 06:37 PM ---------- Previous post was at 06:35 PM ----------
Yeah redneck for sure. But either way, sorry I should have related. Lol
Old 07-21-2012, 06:10 PM   #1315
Filibuster
You can buy shorter pickups for it..not sure if thats the route we'll be takin or just go with the old setup..only reason we didn't run the old pan was for a little more ground clearance. At the moment the camaro still has SB suspension..
And TH what do you mean about the washers for the rivets?..like I just place a washer underneath it?..I do have aluminum rivets.
Old 07-21-2012, 06:21 PM   #1316
Lorraine's driver
ab_mach1's Avatar
These type of washers under the rivets...
Old 07-21-2012, 06:22 PM   #1317
Lorraine's driver
ab_mach1's Avatar
Or any type just to spread out the stress from the hole?
Old 07-21-2012, 06:32 PM   #1318
That's one type.
Steve, You want the washer to fit the rivet snugly so when you cinch it down the washer not the fiberglass takes all of the strain of the rivet expanding. The expanding rivet will pull the washer up good and snug to the bottom of the hood, securing your hood pin plate. Even aluminum rivets will crack and shatter fiberglass.
Old 07-21-2012, 07:21 PM   #1319
Filibuster
That's one type.
Ooohhhhh mylanta...kewl thanks ladies...lol jk
Well the only other thing I got goin on is we installed the cam straight up BUT the marks on the timing gears are both on top instead of bottom and top..they recommend using edelbrock timing gears but I recommend they can suck a fart out of my ***!!!...the engle cam we pulled had the marks the same way and both intake and exhaust valve are closed so im takin the gamble...and no I dont have a degree wheel..
Old 07-21-2012, 08:07 PM   #1320
Lorraine's driver
ab_mach1's Avatar
Hmmm, I'm trying to think of what tool measures fart suckage. Lol!
Old 07-21-2012, 08:25 PM   #1321
The cam gear should have the mark on the bottom and the crank gear on the top normally and those two should be pointing to each other right?
If it's wrong you will be 180° out?
You can get by without a degree wheel, but you will leave a few HP behind sometimes. If your cam was machined on a good day, then you might be ok anyways.
Old 07-21-2012, 09:13 PM   #1322
It's right there above your lips. Best fart detector, measuring device I know of.
Old 07-21-2012, 09:33 PM   #1323
Lorraine's driver
ab_mach1's Avatar
Ha! I'll let Steveo take those measurements with his metering device!
Old 07-21-2012, 10:42 PM   #1324
Filibuster
Yes I am aware of it possibly being 180° off but the old cam and gears were installed top and top..now like I mentioned the edelbrock cam recommends there timing gears but at the same time the engle cam setup had them top and top..so uhh yeah sunny beach!!
Old 07-22-2012, 12:41 AM   #1325
The cam gear and crank gear are different sizes. So if the line up top and bottom they obviously wouldn't line up in the middle. But the reason maybe cause the cam was degrees? I am saying this with very little Chevy knowledge (and buzzed). So keep that in mind.
Old 07-22-2012, 06:36 AM   #1326
Yeah, you have to keep in mind that the cam turns half the speed of the crank.
I wasn't aware that he was working on a GM.
I admit to total ignorance in that case.
Old 07-22-2012, 08:26 AM   #1327
Yeah. That was dumb of me. No one degrees cam that much.
Old 07-22-2012, 09:20 AM   #1328
Not in the least. It is easy for timing and valve train events to be confusing.
I still struggle with it even after years worth of experience.
It's one of those things that if you don't do it everyday, then it will not stay stuck in your mind.
Just reading and thinking about this, I think I may have given some poor user the wrong info a few days back on which way to turn the distributor to advance the timing. I can't remember who or what thread, now that's going to bug the crap out of me for a while.
Old 07-22-2012, 09:54 AM   #1329
Filibuster
In the first pic you can see how the timing marks are different (top and top)
now after that I ran into a different prob...that's when I say I want ”stock length” replacement pushrods. They gave me stock length hardened rods thicker than the pushrod guides grrrr MOFO'S!!..
im prolly just gunna hog out the guides to fit these pushrods.
ID:	60281   Click image for larger version
ID:	60284   Click image for larger version
Old 07-22-2012, 10:22 AM   #1330
Where is the #1 piston?
It should be at TDC and the cam lobes for that cylinder should be on the base circle of the cam (both valves closed).
Hope those guides aren't "hardened" too, or hogging them out will be difficult.
03:59 PM
