What it takes for forced induction and much more... - Page 60 - Mustang Evolution
Old 09-04-2012, 08:55 PM   #2066
Originally Posted by Azure
Yeah that freakin cool.
---------- Post added at 10:46 PM ---------- Previous post was at 10:42 PM ----------
Dream, did you figure out what popped in your rear?
not 100% sure. im going with the pinon bearing. the pinion was hard to spin. when the pop happened a few weeks ago, it just kinda did it, then was fine. i couldnt figure it out at the time. well when i was driving home the other day i heard kind of a ticking/clicking/ whining noise ....or some **** its really hard to pin point noises with the exhaust as loud as it is. but anyways i think just the one bearings shot. but the spider gears are pretty worn and so is the axle splines. but i think i can probably get it back together untl i can budget the good stuff. all i will basicaly need is a bearing, crush sleeve, and pinon nut. oh and some fluid+friction modifier. everything else seems good. my gears are in great shape with a perfect comtact pattern on the gears and both sides of the teeth.
---------- Post added at 09:55 PM ---------- Previous post was at 09:55 PM ----------
Originally Posted by XXSTEVEO66
Ooooo that's what she said!!!
leave it to this guy^ lol
Old 09-04-2012, 09:06 PM   #2067
Re: what it takes...
Originally Posted by XXSTEVEO66 View Post
And what kind of truck was that?..what ”make” was pusshin 500hp?..
I can't remember...huh..it's on the tip of my tongue..
---------- Post added at 04:31 PM ---------- Previous post was at 04:29 PM ----------
Oh and
That's awesome!!
It was a Government Motors truck. (You asked for that. no offense intended.)
Holy Black Smoke Rolling! That Frankenstein Mustang was cooking with oil!
Smells like french fries I bet.
Originally Posted by dreamstang View Post
Yeah yeah it was a Chevy. And a bad a$$ one to. The only one I ever owned, and I will say I miss it.
That mustang is siiick....
On a side note I ripped the rear end out today. Now I just need to see if I can score a deal on some good parts. Also half tempted to try and get this stuff going until I can get some better parts. Hmmm... Idk...lol
You could just rebuild what you have for now and save up for the expensive replacement for later.
hmmmm........
Bery Interestink! Do you have a link to those I would like to read more about them.
P.S. For the support bar to the axle tube, one with adjustable rod ends would work better I think, because you could pre-load (put some pressure) the tubes a bit with those.
Old 09-04-2012, 09:07 PM   #2068
Lorraine's driver
ab_mach1's Avatar
That would be great if you could get it back together enough to drive it, though not spirited. It's cool that you can do the work. Well, and that it's not your DD. And glad you got your creative juices flowing for some upgrades.
Instagram: @ab_mach1
Old 09-04-2012, 09:15 PM   #2069
i was just randomly playing with the google image tab. i used. : axle housing reinforments, diff cover reinforcments.
yeah for a detroit locker with moser axles will run about 1k. its attainable but will take some time. im gonna try to get her back on the road again. prolly a china bearing or some crap. imm put new bearings on it and it will prolly be ok for now.
---------- Post added at 10:15 PM ---------- Previous post was at 10:14 PM ----------
haha. thanx for the support. the only problem is all my driving is done very spiritedly. if it breaks, then so be it. 2 breakages in the same spot will definitly help with the bargaining chip for the wifey to go detroit/moser. muhaha
Old 09-04-2012, 09:21 PM   #2070
Forum Car Trader
90GTNovi2000's Avatar
+1 on that.. If it breaks it was from me beating on it not low grade parts.. Since you do all your own work buy that china stuff lol run it til it breaks and you get the $$.. We have 8 ford 9" housings laying behind my buddies shop. He said I could have one if I clean one up for him to build next yr. I'm getting it this wknd.. Another slow project
90GTNovi2000 is offline   Reply With Quote
Old 09-04-2012, 09:22 PM   #2071
Ok, I can do an image search and maybe find them.
We'll keep an eye open. We might find some used parts that are in good shape. The Detroits are extremely durable and hard to tear up, so maybe we can save you some money on them. Watch the ads on RacingJunk.com. They have some bargains on there occasionally.
P.S. Be sure to check your backlash and wear pattern again after you change out the bearings. I know you probably already know that, I mention it JIC you forget, but then you are not as ancient as I, so maybe you wouldn't either.
Old 09-04-2012, 09:24 PM   #2072
Forum Car Trader
Also yellowbullet.com a great racing part site much better than racing junk IMO
Old 09-04-2012, 09:27 PM   #2073
That's what I'm hoping. To find a good deal on one. The axles themselves are pretty easily attainable.
P.s. a cover like the one I posted maybe durable enough to add support links to. The only negative of going this route is I wouldn't have the bearing support, which stock doesn't either.
Old 09-04-2012, 09:32 PM   #2074
Found the first image at - Ruff Stuff Specialties You can buy them for $125.
My only concern is the weight as they are apparently made from 3/8" steel.
It would be even better if they had included the bearing cap support bolts, but if you build one you can add those yourself I suppose.
Old 09-04-2012, 09:34 PM   #2075
Lorraine's driver
ab_mach1's Avatar
Man, those tie rod ends look really cool!
Old 09-04-2012, 09:38 PM   #2076
Yeah I don't think I would use 3/8
---------- Post added at 10:38 PM ---------- Previous post was at 10:37 PM ----------
All the cap support bolts do is thread a bolt into the cap right?
Old 09-04-2012, 09:57 PM   #2077
Yes, they do.
Yeah, I think 1/4" or 5/16" at the most would be sufficient.
Yes, the bolts have a flat end on them that contacts and supports the bearing caps in the center where the most pressure is when you are launching or accelerating hard.
Old 09-05-2012, 04:06 PM   #2078
ok. after much thinking, project fabbed diff cover in affect. by next payday i will have the stuff i need to get her back on the road. so hopefully i can pull this off before then. hopefully in the next couple days i will have some pics. it will be similar to the one i posted but hopefully a little more rugged and cooler.
p.s i have decided on 3/16" steel. it should be a good mix of not to heavy and pretty strong. im hoping my design will also add to the strength.
Old 09-05-2012, 05:20 PM   #2079
hey steve this is a trailer for that meltdown this weekend at 41.
Old 09-05-2012, 05:43 PM   #2080
Filibuster
That's this fukin weekend!!..sh¡t!! Piss!!! Fuuuuk!!...
I'll just start by sayin women are evil!. I gotta save my $$ to go to this broads place friday night and we're doin somethin definatly not as cool as goin to the track on saturday!..DAMN!!!..ahhhh fml!!..
Maybe ill see if I can twist her arm into going there instead. But that's probably a slim chance :/
Ps. Combo round on pass time 2 fox's
XXSTEVEO66 is offline   Reply With Quote
Old 09-05-2012, 05:46 PM   #2081
Is this the bartender chick?
P.s. I wasn't watching but ill go with a 19.5 anyways.
Old 09-05-2012, 05:54 PM   #2082
Filibuster
Yeah it's da bahtenda chic
P.s. You lose 23.82!..it was an 89 with a ”somewhat stock” 347 ran 12's and an 87 with a 351 ran 11's an the chic wasn't wearing a helmet!...she's prolly from 41 lol
Old 09-05-2012, 06:00 PM   #2083
nice
lol. prolly. haha
Old 09-05-2012, 06:34 PM   #2084
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Buddy just texted me(the one with the rear that snapped like a twig) got his car back together and it's I'm the 12s with 4.10s, full exhaust, upper and lower intake and possibly gt40p heads, not certain if he's still stock cammed or not, runnin on slicks.
His bro says my car should be a 13.80 car, if not I'm doin somethin wrong. I don't care if I drop into the 13s, if I do it'll be bitter sweet but if I'm in the low 14s on street tires ill be content. Them I'm gonna go back with drag radials
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 09-05-2012, 06:39 PM   #2085
That's cool he got it back together.
I will be happy with 13s but I want 12s. My car should easy be capable of 12s but I'm thinking I may have some tweeking and *****.
Old 09-05-2012, 06:47 PM   #2086
Pete Jones
Yeah I keep trying to tell myself low 14s is good so I don't get my hopes up. Then I keep thinking on how immgonna launch it etc etc . I really wanted I go this Friday but the wife has to work Friday night so I gotta get home after work :/
90 LX hatchback
89 LX Notchback
Old 09-05-2012, 06:57 PM   #2087
I think I will be able to still get to the track this year. But after my recent rear end issues I think I'm not gonna take the slicks. So I definitely won't be hitting 12s this go.
---------- Post added at 07:57 PM ---------- Previous post was at 07:53 PM ----------
Don't forget to vote for steveo in motm!!!!!!!
Old 09-05-2012, 07:25 PM   #2088
Pete Jones
Way ahead of ya
90 LX hatchback
89 LX Notchback
Old 09-05-2012, 08:12 PM   #2089
Blown347's Avatar
What's up fellas. Well steveo told me a lot of fox guys post here so I figured I'd join the club
1992 Fox 5.0 S/C 347, The Beast!
1995 GT 5.0 all stock, 168k miles, the beater!
1998 Cobra, Atlantic Blue, 21k orig miles, all original!
Blown347 is offline   Reply With Quote
Old 09-05-2012, 08:15 PM   #2090
welcome to the club. lol
once upon a time this was a build thread. but it has become a place for us to hang, with a small update here and there. lol
Old 09-05-2012, 08:19 PM   #2091
93slowstang's Avatar
Best group ever.
Old 09-05-2012, 08:21 PM   #2092
Lorraine's driver
ab_mach1's Avatar
And dudes who got stuck renting a Prius
Old 09-05-2012, 08:26 PM   #2093
Filibuster
Yeah buddy..good sh¡t goin on in this thread..welcome to the club!
---------- Post added at 09:26 PM ---------- Previous post was at 09:22 PM ----------
Lmao!..i think this should be your avatar until you get the mach back. Then definitely back to futurama
Old 09-05-2012, 08:27 PM   #2094
Lorraine's driver
ab_mach1's Avatar
I guess that's what Imma do since I didn't put up a fight to get something else
Old 09-05-2012, 08:28 PM   #2095
Forum Car Trader
Lmao.. Yes you must make it your avatar.. Welcome blown 347.. Did I miss the initiation ceremony?
Old 09-05-2012, 08:34 PM   #2096
Lorraine's driver
ab_mach1's Avatar
Blown347's initiation period is about another week and he has to take my Prius rental while I drive his fox...huh? huh?
Old 09-05-2012, 08:41 PM   #2097
Filibuster
Oh yeah what's not to like about that!...oh plus I think he has to post a vid!.
Old 09-05-2012, 08:45 PM   #2098
And where's this avatar change azure?
Old 09-05-2012, 08:46 PM   #2099
Lorraine's driver
ab_mach1's Avatar
It's coming, it's coming. Hold on to your britches.
Old 09-05-2012, 08:47 PM   #2100
Filibuster
^that's what she said^ ooooo ya totally set that one up!.
12:19 PM
