What it takes for forced induction and much more... - Page 67 - Mustang Evolution
Old 09-09-2012, 07:27 PM   #2311
Re: what it takes...
Originally Posted by dreamstang View Post
Me to. Most of my projects like this have similar costs.
I wish I could say the same, but honestly most of mine end up costing me a lot more in the end.
Old 09-09-2012, 07:41 PM   #2312
lol. i am what you call resourceful. haha but anyways what about these? i think they will suffice?
http://www.amazon.com/thds-Select-Sw...+pad+load+bolt
---------- Post added at 08:41 PM ---------- Previous post was at 08:33 PM ----------
oh yeah. i was thinking at least 3/8 but with a 1500 lb capacity they should be ok for a support.
Old 09-09-2012, 08:12 PM   #2313
1.00 dia.,1/4-20 thds.,1.95 Lg.,1480 Lbs max load,Select Inch 15o Swivel Stud Style Leveling Pads,Stainless Steel (1 Each): Amazon.com: Industrial & Scientific
Yeah I'd go 3/8" or 1/2" at least, but that style should work.
If there is any rubber or plastic on the bottom you will want to remove that so the heat and oil does not cause it to decay or come loose inside the rear end.
Maybe see if you can find out what the factory studs torque down to?
I don't think it's very much, like 20 ft lbs or so.
Old 09-09-2012, 08:18 PM   #2314
Yeah. I don't think the supports should be tightened very tight. I would be worried about it stressing the center of the bearing. I would think snuffed good should work. I think the cap bolts, if that's what you talking about are actually pretty tight. But its been a while.
Old 09-09-2012, 08:27 PM   #2315
I'm talking about the support studs. They have a torque figure to pre-load the bearing cap center. I'll see if I can find out what it is.
Old 09-09-2012, 08:37 PM   #2316
Oh ok. Thanx
Old 09-09-2012, 08:38 PM   #2317
Here's the LPW Ultimate Installation procedure and torque specs.
Link to PDF - Installation Procedure
Copy/Paste Instructions below:
1. Prepare the housing for cover installation by cleaning the gasket surface and all cover mounting bolt holes.
2. Inspect the bearing caps and gears for excessive wear or cracks, replace if necessary.
3. If Installing LPW main cap stud kit, torque part # 321-4 (7/16”) to 65ft/lbs. Torque part # 325-4 (1/2”) to 85ft/lbs.
4. Remove the load bolt locking nuts and adjust the load bolts so they will not contact the bearing caps during cover installation.
Note: Adjust the swivel feet until they pivot freely on the load bolts before cover installation.
5. Apply silicone gasket sealant to the cover gasket surface. Also apply a small amount to the load bolt threads at the locking nut area to provide a positive seal once the load bolt is adjusted and locking nut installed.
6. Install support cover with all the cover mounting bolts finger tight.
7. Torque the cover mounting bolts. Applications with 5/16” bolts torque to 25ft/lbs. Applications with 3/8” bolts torque to 35 ft/lbs.
8. Torque the load bolts to 10ft/lbs.
Note: Do not exceed 10ft/lbs of torque or bearing distortion and component failure will occur.
9. Install and torque the load bolt locking nuts to 10ft/lbs.
Note: Do not over torque the load bolt locking nuts.
10. Add fluid to the manufacture’s recommended level. If your application has a factory fill plug on the side or front of the housing, it is the correct level to use.
Note: The fill plug on most LPW covers is located higher than the recommended level. Most LPW support covers increase fluid volume approximately one pint.
Applications w/o housing fill plug: Chrysler 8.2 & 8.3, 5 pints / Chrysler 9.25, 5-1/2 pints / Dana 30, 2-1/2 pints / Dana 35, 3-1/2 pints / Dana 44, 4-1/2 pints / Dana 60, 6-1/2 pints / Dana 70, 7-1/2 pints / Dana 80, 10 pints
Note: User and/or installer must make certain the LPW cover will not come in contact with and/or interfere with any suspension and/or chassis component. Do not attach any item(s) other than the LPW axle-tube brace to the ULTIMATE cover. Do not attach any item(s) to the ULTRA cover.
Old 09-09-2012, 08:43 PM   #2318
perfect! also thanx for the link. because a week or 2 on this thread it would be hard to find again.
basically no more than 10ft lbs. it doesnt say in the instructions but i plan on using a thread sealant on those bolts to.
Old 09-09-2012, 08:49 PM   #2319
You're welcome.
I knew it wasn't much torque, but I missed it by 10 lbs too much. That's why it always pays to check.
It says to use a bit of silicone on #5 in the list, but I think some Blue thread locker would serve to seal and keep them from loosening up better.
Did you notice it says on #10 - Note: The fill plug on most LPW covers is located higher than the recommended level. Most LPW support covers increase fluid volume approximately one pint.
Maybe another reason to raise the fill/level check plug?
Old 09-09-2012, 08:52 PM   #2320
You're welcome.
Oh yes I did see that, and was gonna even mention that in my last post and forgot.
Old 09-09-2012, 08:55 PM   #2321
Forum Car Trader
90GTNovi2000's Avatar
Lol.. Ugly coupe look
http://houston.craigslist.org/cto/3257272979.html
90GTNovi2000 is offline   Reply With Quote
Old 09-09-2012, 08:57 PM   #2322
Lorraine's driver
ab_mach1's Avatar
It saddens me to see a fox looiking like that
Instagram: @ab_mach1
Old 09-09-2012, 09:00 PM   #2323
89 ford mustang coup
Poor thing.
It has potential, but sadly I own none of the trade items he wants.
Old 09-09-2012, 09:01 PM   #2324
^ this guy spends serious time craigslisting! lol
Old 09-09-2012, 09:01 PM   #2325
Lorraine's driver
ab_mach1's Avatar
Originally Posted by Trojan Horse View Post
Poor thing.
He's asking for a lot of $
Old 09-09-2012, 09:05 PM   #2326
cause its a foxbody! duhhh lol
Old 09-09-2012, 09:07 PM   #2327
$7,500 or a motor home or a Harley, Dodge or Chevy truck trade.
Old 09-09-2012, 09:10 PM   #2328
Dodge or Chevy truck? That sounds CHEAP to me. Lol ......ok where's Steve?
Old 09-09-2012, 09:10 PM   #2329
Lorraine's driver
ab_mach1's Avatar
Lol! I guess there's that.
Old 09-09-2012, 09:11 PM   #2330
Forum Car Trader
Yesss I love looking at foxes.. How you think I got mine so cheap.. I'm always looking for a quick flip
Old 09-09-2012, 09:14 PM   #2331
Lorraine's driver
ab_mach1's Avatar
If I picked up a fox, it eventially have to get mods. , my wife would kill me.
Old 09-10-2012, 12:45 PM   #2332
Dion11197's Avatar
I got lucky, my wife wanted to "restore" one! Lol
Dion11197 is offline   Reply With Quote
Old 09-10-2012, 12:51 PM   #2333
Lorraine's driver
ab_mach1's Avatar
That's awesome! Yup, she hates the little things that always pop up when your modding your car.
Old 09-11-2012, 05:49 AM   #2334
Dion11197's Avatar
Yeah, I've been through that before too! And there's always something that pops up or that gotta have it part!
Old 09-11-2012, 09:13 AM   #2335
Stang.racr's Avatar
First speeding ticket in five years. 73/60. Blah
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 09-11-2012, 11:10 AM   #2336
Lorraine's driver
ab_mach1's Avatar
DOH!
Old 09-11-2012, 11:22 AM   #2337
That sux.
Old 09-11-2012, 06:39 PM   #2338
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Shoulda said you really had to poo, friend of mine did that once when we would carpool to school, got a good chuckle from the cop and let us go with a warning lol
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 09-11-2012, 06:48 PM   #2339
haha. thats a good one!
Old 09-11-2012, 06:50 PM   #2340
Lorraine's driver
ab_mach1's Avatar
At least he didn't have to prove by presenting a stink pickle!
Old 09-12-2012, 05:56 AM   #2341
Dion11197's Avatar
+1! I've also seen it in action. My buddy actually had to go, but got him out of a 85 in a 40!
Old 09-12-2012, 06:35 AM   #2342
Lorraine's driver
ab_mach1's Avatar
Felt good to drive into work with a real car today.
Old 09-12-2012, 08:03 AM   #2343
Pete Jones
That's what she said
90 LX hatchback
89 LX Notchback
Old 09-12-2012, 08:09 AM   #2344
Lorraine's driver
ab_mach1's Avatar
Lol
Old 09-12-2012, 12:39 PM   #2345
Dion11197's Avatar
Nice! Hahaha!
09:14 PM
