Smog pump. - Mustang Evolution
Old 09-22-2011, 09:57 AM   #1
89 Foxloco's Avatar
Smog pump.
I installed an x pipe on my mustang.would their be a problem if I block the hose??
89 Foxloco is offline   Reply With Quote
Old 09-22-2011, 12:32 PM   #2
Re: Smog pump.
If it is still pumping, then yes there is likely to be a problem if you just block it off.
It may build up excess pressure and blow the hose apart or lock up the pump and burn up the belt.
Old 09-22-2011, 01:29 PM   #3
89 Foxloco's Avatar
Than what options do I hav? It's cuz I put the x pipe.and they canceled the smog tube.so idk what to do.what are the consequences of not having the pump working.
Old 09-22-2011, 03:05 PM   #4
EHP
EHP's Avatar
Re: Smog pump.
I am guessing where you are located their are no emissions testing? I was stationed in Little Rock a lonnnngggg time ago and frequently visited your home state! You can eliminate the smog pump if that is so.....many companies make the elimination kit that retains your original belt length, UPR makes one......
EHP is offline   Reply With Quote
Old 09-22-2011, 05:53 PM   #5
crkmonzo's Avatar
Re: Smog pump.
the majority of the fox bodys ive seen ive never seen a smog pump lol
crkmonzo is offline   Reply With Quote
Old 09-22-2011, 06:35 PM   #6
Filibuster
This is a pic Trojan horse posted on one of my threads about deleting the smog pump for my car...
You can just bypass the pump with a shorter belt...
XXSTEVEO66 is offline   Reply With Quote
Old 09-22-2011, 08:14 PM   #7
93slowstang's Avatar
+1, I bypassed mine and took the dead weight out. Have to cap the tube to the back of the heads off.
Old 09-23-2011, 08:11 AM   #8
89 Foxloco's Avatar
I have this pictures thanks though.I have a question regarding this.is it true that the less pulleys the belt has on it the better more power??
Old 09-23-2011, 08:32 AM   #9
The less restrictions on the motor the less amount of power being robbed.I wouldn't give power steering for a d/d and the ac really only robs power when its running.some people even go to electric water pumps.and lots of people toss the smog.
Old 09-23-2011, 03:08 PM   #10
89 Foxloco's Avatar
So should I just toss the smog pump and get the shorter belt or should I keep it??
Old 09-23-2011, 03:14 PM   #11
I would say toss it.
Old 09-23-2011, 03:18 PM   #12
Re: Smog pump.
Does it still work?
Want to sell it if it does?
How much?
Old 09-23-2011, 04:12 PM   #13
Originally Posted by Trojan Horse
Does it still work?
How much?
u use the smog?just wodering
Old 09-23-2011, 06:38 PM   #14
Re: Smog pump.
If it works I can use it for a crankcase evacuation pump.
Old 09-23-2011, 06:41 PM   #15
hmm ,never heard of that.to keep pressure from heat down?
Old 09-23-2011, 06:51 PM   #16
Re: Smog pump.
Yes & No, it is to pull a vaccum on the crankcase, which is especially useful in SC & TC applications.
Helps eveything seal up better including your rings and keeps you from leaking oil all over.
With a SC/TC you can actually have positive pressure in the crankcase which is definitely not a desirable condition.
Ever seen a car push smoke/oil vapor out of a valve cover breather?
It is usually caused by bad ring seal from worn out or damaged rings.
Compression leaking past the bad piston rings and pressurizing the crankcase is most commonly the cause.
Old 09-23-2011, 06:56 PM   #17
interesting.makes sense.learn something new everyday. : )
Old 09-23-2011, 08:42 PM   #18
89 Foxloco's Avatar
Amazing..never heard of anything like that..lol..
---------- Post added at 02:42 AM ---------- Previous post was at 02:41 AM ----------
Does it still work?
How much?
Yes it does works.I'll let you know shortly how much..where do you live??
Old 09-23-2011, 08:48 PM   #19
Re: Smog pump.
Fayette, Missouri
Bad Fuel Pump?? jal4411 1979-1995 Mustang GT 7 09-17-2011 02:32 PM
Think water pump is gone? Whiterocknotch 1979-1995 Mustang GT 11 09-04-2011 08:39 AM
smog pump shawnpbigelow 1979-1995 Mustang GT 1 08-30-2011 08:40 AM
Smog pump delete XXSTEVEO66 1979-1995 Mustang GT 11 08-23-2011 03:18 PM
08:54 AM
