Engine Rebuild Kit form summit - Mustang Evolution
Old 09-22-2011, 10:14 PM   #1
kbolden50's Avatar
I wanted to know are sealed power engine rebuild kit can with stand a mid cam with gt-40 heads and some other little things cold air intake shortys headers under drive pulleys no more than 400hp I think and would it be better to get pistons forged or hypereutectic I no forged is stronger but will the hypereutectic put up with 400hp and be fine
kbolden50 is offline   Reply With Quote
Old 09-22-2011, 10:32 PM   #2
Re: Engine Rebuild Kit form summit
It will work fine for what you want.
Forged pistons are better, but the hypereuctic should hold up ok unless you plan to SC or TC it later.
Old 09-23-2011, 01:00 PM   #3
kbolden50's Avatar
Ok good seems to be a go deal also is a 1986 block good to start form and is this a 86 block what dose all the numbers and letters
ID:	32081   Click image for larger version
Old 09-23-2011, 01:09 PM   #4
The top left picture says it is an 87 (E7) block.
The rest of the numbers I'm not sure, but I think they are casting numbers.
Old 09-23-2011, 01:38 PM   #5
kbolden50's Avatar
Is that a good year a strong block do you no what the S means and CA
Old 09-23-2011, 02:31 PM   #6
It's as good as any other roller block and it will be fine for most uses.
If you plan on high HP, TC or SC then I would go with an aftermarket 4-bolt main block if it fits your budget.
I don't know what the other letters mean, sorry.
Do a search on Google for 5.0 engine block number or tags decoding and you may turn up some explanations.
Old 09-23-2011, 03:30 PM   #7
93slowstang's Avatar
Got it, here's a link to decoding the block. Your second pic is the date code which is august 28 1986
http://www.classicmustang.com/decoding_part_numbers.htm
Old 09-29-2011, 02:53 PM   #8
kbolden50's Avatar
Someone was telling me about a 4 bolt main what it the difference in the block form 4 bolt and stock cast iron
Old 09-29-2011, 03:03 PM   #9
Standard block has 2 bolts per main bearing cap, a 4 bolt main has 4 bolts on certain main bearing caps, can't remember which ones at this moment. 4 bolt is supposed to be able to handle more hp.
Old 09-29-2011, 04:00 PM   #10
86gt's Avatar
The FRPP boss block has 4 bolt mains on the #2, 3, and 4 main caps and is the strongest block out there other than the dart block which is about the same!
86gt is offline   Reply With Quote
Old 09-29-2011, 04:34 PM   #11
And also the Boss block has thicker cylinder walls, which makes it capable of being stroked to a 363 as well.
« T5? | MPG?? »
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
Engine rebuild north of Chicago ? Rewbeez Classic Mustangs 1 07-23-2011 01:10 PM
08:26 AM
