92 GT having fuel issues when hot ? - Mustang Evolution
Old 09-23-2011, 07:38 PM   #1
ebourd's Avatar
Any have any ideas I changed my fuel pump cause it completely died now I keep having issues with losing fuel pressure like my car is starving for gas when it gets hot I've changed mass air throttle position sensor and relays do I need to go back to tank ?
ebourd is offline   Reply With Quote
Old 09-23-2011, 09:28 PM   #2
Re: 92 GT having fuel issues when hot ?
Are you actually losing fuel pressure?
Have you checked/replaced the fuel pressure regulator?
Old 09-23-2011, 09:33 PM   #3
ebourd's Avatar
No I haven't maybe that's next it seems only when its hot out and after a good twenty minutes or better of driving if I let it set for a while it's good
Old 09-23-2011, 09:36 PM   #4
Old 09-23-2011, 09:39 PM   #5
ebourd's Avatar
It feels like I'm running out of fuel I can pump pedal it feel like I'm running out of gas like it's starving and without putting pressure tester on I'm not sure
Old 09-23-2011, 09:43 PM   #6
You need to check that and if you are then it is likely the regulator.
If not, then I would suspect an electrical problem with the pump maybe.
Old 09-23-2011, 09:48 PM   #7
ebourd's Avatar
Alright I'll check it mañana then I'll repost but it's a auto zone fuel pump so I'm guessing it's that just dreading dropping the tank again
---------- Post added at 08:48 PM ---------- Previous post was at 08:47 PM ----------
Old 09-23-2011, 09:53 PM   #8
I'd go ahead and replace the regulator too.
2006 GT 350 theivanoff 2005-2010 Mustang GT 15 09-20-2011 05:16 PM
Intake Suggestions..... Srohda 2011-2014 Mustang GT 42 09-19-2011 03:56 PM
Mustang GT Fuel Injector 504 Stang Rida 1996-2004 Mustang GT 4 09-01-2011 09:12 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
94 mustang gt is running hot!!! 94 GT 1979-1995 Mustang GT 20 07-01-2011 02:45 PM
06:57 AM
