93 mustang not getting spark - Mustang Evolution
Old 09-24-2011, 06:19 PM   #1
Chefnick's Avatar
I have a 93 mustang. When I turn the ignition to the auxiliary position it sparks bit when I crank it I get no spark. Any suggestions?
Chefnick is offline   Reply With Quote
Old 09-24-2011, 06:57 PM   #2
coil or distributer?
HaulinTwinz is offline   Reply With Quote
Old 09-24-2011, 07:04 PM   #3
Do u have an msd coil on it?
Hawk is offline   Reply With Quote
Old 09-24-2011, 07:48 PM   #4
Chefnick's Avatar
Stock coil. And I get spark at the coil. One spark when turn key before I crank it over
Old 09-24-2011, 11:11 PM   #5
93slowstang's Avatar
Have you replaced the coil recently or at all? The coil may be bad.
Old 09-25-2011, 05:41 AM   #6
Chefnick's Avatar
No but it was to my understanding that because I was getting that initial spark every time that it was not the cool.
Old 09-25-2011, 07:15 AM   #7
Chefnick's Avatar
Coil
Old 09-25-2011, 10:29 AM   #8
The coil has to be able to hold a charge to provide a consistent spark.
Old 09-25-2011, 04:18 PM   #9
Re: 93 mustang not getting spark
You need to remove a spark plug, put the wire back on it, lay it on the engine in a manner that it can get good contact with the lower metal portion of the spark plug and then watch it and have someone else turn the engine over a few times and see if there is spark at the plug.
If there is then you have some other problem.
If there is not then check your TFI module.
Name:	EEC-IV TFI Tests.jpg
Old 09-25-2011, 11:41 PM   #10
I had very similar problems... Unfortunately I never solved it myself. It was a random issue that happened hot or cold, but it fixed itself it seems. The only guess I have would be the ignition switch itself, it might have been loosing contact because it was the only thing that I screwed with that made a difference...
RedRustang is offline   Reply With Quote
Old 09-26-2011, 05:00 AM   #11
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
I've heard foxbodies are known to have ignition switch problems. They basically just fall apart after a while, knock on wood I haven't had that problem yet.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 09-26-2011, 08:46 AM   #12
stampde's Avatar
tfi module
2011 GT Auto
Old 09-26-2011, 10:49 AM   #13
Posse5.8stang's Avatar
Pick up coil inside your distributer
Posse5.8stang is offline   Reply With Quote
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
07:19 AM
