94-95 GT Build stickers - Mustang Evolution
Old 09-28-2011, 01:14 PM   #1
deadsp0t's Avatar
A little help please.
I asked this question in another thread with no luck so here goes.
On the passenger side valve cover there is a white sticker with some numbers, which is just ID numbers I guess. But in one corner there is a big +10 on it. Anyone know what this means? I've searched the Internet but maybe I'm not holding my face right?? Could this be +HP or +TQ? a tolerance? +10 min or miles on a test? +10MPG? Could it just be something Ford uses internally?
That's unimpressive
Old 09-28-2011, 01:24 PM   #2
93slowstang's Avatar
I know I searched before to no avail. Guess I'll try some more for ya since it's been on the back of my mind since you asked.
Old 09-28-2011, 01:43 PM   #3
Re: 94-95 GT Build stickers
All I could find was that it is a decal off of a 1995 Cobra R
It is the engine calibration code, so it could mean +10 degrees advance on the timing maybe?
Old 09-28-2011, 02:21 PM   #4
jwhayne0001's Avatar
Can you find a used passenger valve cover?
---------- Post added at 03:21 PM ---------- Previous post was at 03:20 PM ----------
Never mind i missunderstood i assumed you wanted a replacement decal
jwhayne0001 is offline   Reply With Quote
Old 09-28-2011, 03:27 PM   #5
deadsp0t's Avatar
That would be the sticker! I will try to email customer service to see maybe if they know what everything means! Thanks! Did not even think to look on LMR!
That's unimpressive
Old 09-28-2011, 03:43 PM   #6
You're Welcome.
I spent 30-45 minutes searching, but that was the best info I could find.
All kinds of vin and engine block decoders, but no calibration decal decoders.
Old 09-28-2011, 04:00 PM   #7
deadsp0t's Avatar
I tried searching one for a GT on LMR to no avail. Thanks again though!
That's unimpressive
Old 09-28-2011, 04:15 PM   #8
Dang it!
Post a picture of your decal and I'll keep looking around.
As much info as there is on the net you just know it is on there somewheres, but finding where "there" is can be a pain some times.
Old 09-28-2011, 04:32 PM   #9
deadsp0t's Avatar
It maybe tomorrow as it will be dark at my break time, but I'll try any way.. It looks identical to that 'R' model decal you posted w/ diff numbers I assume(except the +10). but I will still take a pic.
That's unimpressive
Old 09-28-2011, 04:37 PM   #10
Ok that will be fine.
I want to compare them and see if it makes a little more sense to me.
Old 09-28-2011, 05:55 PM   #11
deadsp0t's Avatar
Here ya go. I can take more in the day time if ya want better ones
That's unimpressive
Old 09-28-2011, 06:38 PM   #12
wc3john's Avatar
could it mean timing at ten degrees advanced?
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 09-29-2011, 09:09 PM   #13
Those were fine.
I did quite a bit more research and still came up empty though.
I did find some for older Ford cars, but nothing comparable or useful.
They are also called Paper Engine Tags is about the only thing I learned.
You might try asking at a Ford dealership as a last resort.
Sorry,
TH
Old 09-29-2011, 09:19 PM   #14
deadsp0t's Avatar
Cool TH, thanks for the effort man. I'm going to send some emails and stop by the local dealership. When(not if) I find out I will post the details.. Someone knows, and this has peaked my curiosity.
If anyone comes up with anything feel free to chime in.
That's unimpressive
Old 09-29-2011, 09:28 PM   #15
Brett Greene's Avatar
Timing is set 10 degree more. The last half of the year were made like this.
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 09-29-2011, 09:44 PM   #16
deadsp0t's Avatar
I understand timing and how it works, just wondering what FoMoCo's reasoning behind this was....?
---------- Post added at 11:37 PM ---------- Previous post was at 11:35 PM ----------
Also I will assume you have this on good authority and I thank you.
---------- Post added at 11:44 PM ---------- Previous post was at 11:37 PM ----------
I also wonder if the mark on the distributor represent the normal base timing or the +10 base timing. Right now I have the marks lined up.
That's unimpressive
Old 09-29-2011, 10:12 PM   #17
We have the same color car.
Hawk is offline   Reply With Quote
Old 09-29-2011, 11:56 PM   #18
10 degrees more than what?
The base timing is set at 10 degrees advanced which would be +10.
Then the computer controls the advancement and retardation as needed from there.
Old 09-30-2011, 10:54 AM   #19
deadsp0t's Avatar
If it were +10 on top of the base +10, would be 20 degrees initial advance. Which would require premium fuel among other considerations...? Also that would make the total timing way too high, like over 40?? Total timing should be in the mid 30's right??
That's unimpressive
Old 09-30-2011, 11:42 AM   #20
Yes, that was my point.
It cannot be +10 on top of the base timing.
And of course our assumption that it even refers to timing may be way off base.
Old 09-30-2011, 12:48 PM   #21
deadsp0t's Avatar
I had thought originally may refer to bore or stroke, but in that case it would be .010 or something of that nature.
Was actually hoping by this point someone would chime in with "well mine say's X"
X=something different then 10
That's unimpressive
Old 10-01-2011, 11:36 AM   #22
deadsp0t's Avatar
82 GT w/ and w/o AC say 12+
84 SVO says +10
83 GT 5spd says 10+
95 Cobra R says +10
85 GT 5spd says +12
84 GT EFI says nothing relevant
86 GT says +10
Beginning to think it's just a ref to base timing
---------- Post added at 01:36 PM ---------- Previous post was at 01:22 PM ----------
84 SVO says +10
83 GT 5spd says 10+
95 Cobra R says +10
85 GT 5spd says +12
86 GT says +10
These are off the engine calibration code decals on Latemodelrestoration.com
That's unimpressive
Old 10-01-2011, 07:16 PM   #23
I agree. Your research certainly points in that direction.
Old 10-01-2011, 07:46 PM   #24
deadsp0t's Avatar
I still want to know for sure and await replies to my email(s).
That's unimpressive
Old 10-01-2011, 08:28 PM   #25
Yeah, surely someone out there knows.
Old 10-01-2011, 08:33 PM   #26
deadsp0t's Avatar
I joined the forums on LRS, but having trouble posting from my phone. Guess I have to break out the laptop
That's unimpressive
Old 10-05-2011, 10:44 AM   #27
Region: Utah
I have a 1994 Mustang GT Convert with the same +10 sticker
Paul
Happy TRAils/NSd
1994 Mustang GT Convertible
pegasus1300 is offline   Reply With Quote
Old 10-07-2011, 08:19 AM   #28
wc3john's Avatar
Im pretty sure it just means base timing at 10 degrees advanced. What ford windsor v-8 ISNT advanced ten degrees for base timing?
Removing Stickers?! KaleoV6 2005-2010 V6 Mustang 14 10-14-2011 08:55 AM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
Tryin to build up my 94 GT 5.0 sweet94GT General Car Discussion 0 07-26-2011 05:09 PM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
10:23 AM
